Will a Command Station suite my needs?
2003-06-02 by sincultura13
I'm mostly working with software sequencing these days, but was
offered some live spots and want to see if I can find a way to
translate what I'm doing on my computer for live gigs. The thing is
that I don't sequence the whole songs in midi, but build block with
loops I make by sampling myself playing, breaks, etc.. I do use midi
but print to audio to sequence. Then I lay some track of me playing
live all the way through and edit... My messed up NLDed brain tends
to get easily overwhelmed with midi sequencing... I rather work with
chunks instead of individual notes.  For the live sets, I was
thinking of adding a DJ CD players and an effect unit to add to my SP-
505 and ESI2000 but then Checking Musician Friends I saw the XL-7 for
$500 which is a sweet deal. Is emu gonna stop making it? 'cause the
MP-7 is still regular price... It occurred to me that I can load all
the big loops to my ESI2000's 128mb of ram and sequence them with
midi in Logic kinda like I do with audio....
Here are some questions I have about the XL-7:
1)USB: IS the USb reliable for loading SMF files from a computer? Can
it load patterns, or just complete songs? If it doesn't load
patterns, what's the step editing like? Is the memory that it comes
with for patterns enough or do I need a flash ram card? It's wierd
that it has no Floppy drive...
2)ROMPLER: What's the sound rom like? IS there a list of the presets
somewhere?I'm not into electronica, but don't want to pay extra for
the MP-7 since I'm mostly using samples anyway. Does it come with
acoustic drums and non Synth patches too? It'll be cool if I could
use some of the onboard sounds especially with all those knobs to
tweak! :)
3)Sequencer: Does the sequencer let you mute/unmute any combination
of the indivudual 32 tracks on the go? Can more than one pattern be
played at the same time? I'm trying to figure out ways keep the vibe
form my computer tracks... I never pay too much attention bars/beats
(and use seconds/minutes and wave display on my audio sequencer as
reference) and might feel constricted by that on the sequencer.
Anybody who's has the same "problem", found a way(s) to work around
this?
I come from playing live instruments on improvisational settings...
Any help, advice, suggestion regarding the Command Stations or any
other possible setup for what I'm trying to do will be greatly
appreciated...
Thanks in advance...
Re: Will a Command Station suite my needs?
2003-06-02 by robotchas
Haven't used it yet. USB is PC-only, if that matters.
I like the sample set, lots of basic synth waveforms which is what I
wanted, but it is VERY electronic: other than some of the drumkits
there's next to nothing in the way of acoustic instrument samples.
You may want to wait for the PX-7 (nothing but drums) and hope the
price drop isn't temporary. Or, buy the XL now and get the P2500 ROM.
16 tracks control up to 32 internal and 32 external channels (tracks
can be multichannel). Think of the tracks as mute groups - you can
also play channels that are not assigned to a track via pads, MIDI
input or arpeggiator triggers.
One pattern at a time but song mode basically lets you play a linear
multichannel track over a pattern chain. Like all pattern-based
sequencers you pretty much have to start thinking in terms of bars
and beats instead of just freestyling it when you're recording, but
in playback you can think of each track as a loop, with X-MIX you
could just keep dropping loops in and out all night long.
Musician's Friend has a 45-day return policy so if you're careful you
could try one and just pay shipping if you don't like it.
--- In xl7@yahoogroups.com, "robotchas" <robotchas@y...> forgot to
mention:
I
There are at least partial sample lists for some of the sound roms on
the emu site, and the XL-7 pdf manual (see Files) contains a complete
list.
Re: [xl7] Will a Command Station suite my needs?
2003-06-02 by erik_magrini@Baxter.com
>>>Yes, works fine for me at least. <<<
Can it load patterns, or just complete songs?
>>>Both. <<<
Is the memory that it comes with for patterns enough or do I need a flash
ram card? It's wierd that it has no Floppy drive...
>>>It has no flash card slot either, no external storage at all in fact.
But the internal memory is huge, so you shouldn't have any issues, and it
sounds like you have a PC anyway, so you can use this to back up if need
be. <<<
somewhere?I'm not into electronica, but don't want to pay extra for the
MP-7 since I'm mostly using samples anyway. Does it come with acoustic
drums and non Synth patches too? It'll be cool if I could use some of the
onboard sounds especially with all those knobs to tweak!
>>>The sounds are good, though the Xl-7 has a lot of synth based sounds.
there are some acoustic samples, but if you're after more natural sounds,
then I'd recommend the P2500 ROM. <<<
3)Sequencer: Does the sequencer let you mute/unmute any combination of the
>>>It's actually 16 tracks (yes, freely mute-able), but 32 channels. A
track can be more than 1 channel if need be, very flexible in this
regards. <<<
Can more than one pattern be played at the same time?
>>>Not really, but with X-MIX you can combine different tracks from
various patterns into the current one. <<<
I'm trying to figure out ways keep the vibe form my computer tracks... I
reference) and might feel constricted by that on the sequencer.  Anybody
who's has the same "problem", found a way(s) to work around this?
>>>Trying to come from a computer based mentality to the XL-7 is not
always the best way to do it, as they're largely very different.  Not a
slight on Emu's part, but audio sequecing doesn't translate well to any
midi based device IMO.  Don't get the XL-7 and try to get it to fit your
current working methods, better to adapt to the way it wants you to work
and work from that perspective, far more gratifying. <<<
2003-06-03 by sincultura13
Thanks for taking the time to help me out....
You both mentioned  the X-mix feature... "Not really, but with X-MIX
you can combine different tracks from various patterns into the
current one." Could you further explain this a bit? That I can take
phrases from different places and make them into a new one?
>>I can't get a mental picture of what you explained... That is one
of the reasons midi sequencing is kinda hard for me. I have a hard
time making mental pictures of abstract things like the structures
the numbers make on a  midi sequence.
"Like all pattern-based sequencers you pretty much have to start
thinking in terms of bars and beats instead of just freestyling it
when you're recording, but in playback you can think of each track as
a loop, with X-MIX you could just keep dropping loops in and out all
night long."
>>> I think what you mean (thought not sure 'cause I don't know how
the X-mix works)is what I had in mind and why I asked about the
muting of channels... Maybe I should give the method a try.. I have
an old roland keyboard with sequencer here...
"Not a slight on Emu's part, but audio sequecing doesn't translate
well to any midi based device IMO. Don't get the XL-7 and try to get
it to fit your current working methods, better to adapt to the way it
wants you to work and work from that perspective, far more gratifying"
>>> That's what I'm kinda worried about... Is not that I don't want
to switch, I just don't know if I'm going to be able to adapt. I have
a hard time with lineal thinking when many variables have to be taken
into account. I used to get all the notes rights in my music
dictation class but the order and rhythm were always all messed up! I
could go to the piano and play them though.  My brain is messed up
that way... I think I'm at my best when I don't have to think about
what I'm doing. :) I don't know if sequencing this pattern based way
is more than I can handle... I can do drums (and what not) that way,
but in my ten years of working with midi have never being able to the
whole thing that way...
Thanks again, and any further advice is still very appreciatted....
2003-06-03 by robotchas
Don't listen to anything rEalm tells you. He's a known pathological
liar. Only listen to what I say.
MIX
Each pattern consists of a block of 16 tracks (parallel MIDI loops
all the same length, up to 32 measures - or 128 beats - long).
Normally when you switch patterns all 16 tracks switch
simultaneously. XMIX allows you to do live remixing by replacing any
track with any other track from any other pattern, one at a time
(they will stay in synch). So instead of an abrupt switch of all 16
tracks you can change the bassline, then the melody line, then the
drums...this is in addition to muting and unmuting tracks. See the OS
2.0 manual addendum (in Files) for more details.
It's probably simplest when you're starting out to just use one
channel per track and forget that multichannel tracks even exist, but
they're there if you ever need them. Similarly, keep your patterns
simple until you're comfortable with what you're doing.
have
taken
I
way
way,
If you can do drums you'll probably be fine. Just program a drum loop
on the beat and then play over the top of it. And if you're
recording, stop playing when you hit the end of the loop.
I have no formal musical training and when I started messing around
with electronic gear I just played stuff into a linear sequencer as
if it were a tape recorder, with no regard for tempo or beat markers.
But once I started programming rhythms (on an old Roland drum
machine) I gradually figured out how the whole bar/beat thing worked
and it helped a lot. I still work pretty intuitively, I can't read
music and couldn't tell you what key I'm in most of the time (I know
what C major is). Most of my musical heroes are the same way.
Like I say, you can check one out and then return it if it doesn't
work the way you'd like.
RE: [xl7] Will a Command Station suite my needs?
2003-06-03 by Stu
At hte risk of being flamed, I think you should also look at the Yamaha
RM1x, as you already have the ESi2000 and the RM1x is a very powerful
hardware sequencer that would work well with your sampler...
It's main strengths are that you can trigger 16 patterns, each made up of 16
tracks, on the fly and can also mute/unmute groups of tracks at the press of
a single button...
It has some very usable drumkits, especially the breakbeat and dnb kits and
their variations, and also features a complete GM set in addition to the
dance orientated sounds...
It has a floppy drive and loads SMFs, patterns or complete songs....
You can select patterns from other songs and play them in the current
pattern (although they won't play immediately - you have to wait until the
loop starts again).
You can have patterns of different lengths playing alongside each other (e.g
a 3 bar pattern looping over a 4 bar pattern). Patterns can be up to 256
bars long....
You can 'timestretch' the patterns in realtime (e.g. make them play at
half/double the original tempo).
You can chain patterns together, then record yourself playing over the top
of them in song mode.
All in all ,it's a very powerful piece of kit, especially if you use it to
sequence external gear such as your sampler. It's internal sounds aren't as
good as the XL-7, but are still usable and you get more variation, although
the XL-7 can be expanded to include other sound sets...
I come from an improvisational background myself, and after deliberating for
quite a while ended up with an RM1x rather than an XL7, partly due to price,
but partly because I felt the RM1x gave me more freedom of expression when
sequencing external gear (I use it with an EMu E6400 Ultra sampler with the
RFX32 expansion - an excellent combination). I think if the internal sounds
are important to you, then go with the XL-7, but if you are intending to
trigger other gear, then get the RM1x.
Stu
(p.s. I have nothing bad to say about the XL-7 or its users, it's just the
RM1x suits my own personal requirements better and I can't afford both
unfortunately...)
  Sent: 02 June 2003 07:28
  Subject: [xl7] Will a Command Station suite my needs?
  tweak! :)
  this?
  appreciated...
        Yahoo! Groups Sponsor
2003-06-04 by Nathan Seven
I've owned both- just wait until your rm1x's buttons
stop working :-/
Also- the one thing that killed me with the rm1x is
that there didnt seem to be a way to change a
pattern's legnth after you created it.
And- the rm1x's note-input buttons are on/off
switches- IE: no velocity-
So you'll need a keyboard or something else unless you
wanna tediously go and edit velocities for everything
you play.
--- Stu <routerman@...> wrote:
> Hi,
> look at the Yamaha
> is a very powerful
> sampler...
> a single button...
> complete songs....
> them in the current
> loop starts again).
> bars long....
> make them play at
> sets...
> Regards,
> Stu
> can't afford both
> unfortunately...)
>   -----Original Message-----
>   From: sincultura13 [mailto:sincultura13@...]
>   To: xl7@yahoogroups.com
> needs?
> days, but was
> find a way to
> gigs. The thing is
> build block with
> etc.. I do use midi
> track of me playing
> NLDed brain tends
> I rather work with
> sets, I was
> I saw the XL-7 for
> that I can load all
> sequence them with
> doesn't load
> card? It's wierd
> list of the presets
> to pay extra for
> Does it come with
> cool if I could
> those knobs to
>   tweak! :)
> than one pattern be
> ways keep the vibe
> audio sequencer as
> the sequencer.
>   this?
> Stations or any
> will be greatly
>   appreciated...
> Terms of Service.
> [Non-text portions of this message have been
> removed]
> http://docs.yahoo.com/info/terms/
http://www.thedenofsin.org/
AIM: IMFDUP
2003-06-04 by sincultura13
Thanks for all the responses...
The RM1x was one of my other options, especially 'cause they can be
found cheap used. ALso, I'm moving close to a friend who has one &
can help me out. He told me about the Buttons but it doesn't make any
difference to me 'cause I have two keyboards here. The Lx-7 for some
reason appeals to me more... Maybe 'cause I have the ESi. BTW, my ESi
came with 3 cds full of sounds banks and most of them are synthy
sounds but older simpler editions? and you have to tweak them for
them to sound good. I have a Qs8 from where most my bread and Butter
sounds come from...  I also, thought about getting a QY700 since
people say that it's the closest thing to a software midi sequencing
in hardware, but since I haven't had success with software midi
sequencing in the first place I'm not sure if that's the way to go...
I can't order the  Xl-7 from Musician's Friends without being
sure 'cause I'm going to use the X month no interest offer to buy it
and If I return it I'm going to be Stuck with a $530 credit with
nothing else to buy from them... A good idea though.
The only other Idea I have is to get a used mac laptop or maybe
finance a "cheaper" 12" new one to use with appleton Live 2. I'm
kinda resisting the idea 'cause I have a really nice PC already and
I'm kinda weary of playing live with a computer...
I haven't had a chance to try the MC909 niether and had an MPC here
for some time and awesome as it is, I rather have something more
flexible for live gigs... Are there any other hardware sequencer
options I should consider?
2003-06-04 by robotchas
> found cheap used.
The RM1x is not a bad box, as Stu points out, and may be more your speed
both sound and sequencer-wise. It seems better for sequence editing but not
as good for live performance, but YMWV.
If you meant "wary", Live is supposed to be quite stable. I looked into using it a
while back. I'd say try the demo on your PC for a couple weeks and see how it
feels.
You may not need a laptop either - if people can bring 240 lbs of bass amp
onstage, a computer is not a big deal.
If you meant "tired" then I hear you.
Not really. The 505 is better than the 909 for live performance (though the 909
does have some cool features for studio work). But I'm one of the people who
thinks the MPC is highly overrated. And the Electribes are cool toys but very
limited.
Re: [xl7] Re: Will a Command Station suite my needs?
2003-06-04 by biz
> found cheap used.
Actually, I'd disagree on this - I found it better than the emu at some
parts of live performance, and quirkier for editing. Then again, I much
prefer software and a keyboard over any hardware interface.
The strength of the RM1x is in importing stuff you've written elsewhere, but
want to play/improvise on live - the midi import is perfect, and the midi
i/o set up is easier than the xl-7. You can load a software sequence via
floppy, and then chop it up into loop sections in the RM1x and have it
playing on the RM1x and external midi units in seconds flat - none of the
craziness of importing files into the xl-7.
I used the RM1x for playing the song structure back, and then trigger loops
over it with the xl-7.
bIz
http://www.groovetronica.com - "No offense, but a dated d&b loop with some
Holiday Inn lounge singer hardly wows me technically or talent wise, and I
could do better with a cassette deck and a microphone."
Sent: Wednesday, June 04, 2003 10:59 AM
Subject: [xl7] Re: Will a Command Station suite my needs?
> found cheap used.
using it a
it
feels.
909
very
limited.
2003-06-04 by erik_magrini@Baxter.com
>>>It'd be heat and smoke that would worry me personally more than actual
weight though. <<<
2003-06-04 by biz
>weight though. <<<
It's the vibration and travel damage that would concern me more than the
heat, smoke and weight. Laptops aren't just small - their moving parts, such
as the hard drives, are designed for traveling abuse.
bIz
http://www.groovetronica.com - "The beats are ok, I suppose, but the vocals
sound like the vintage jazz singers from my dad's record collection. It's
not for me."
Sent: Wednesday, June 04, 2003 11:26 AM
Subject: Re: [xl7] Re: Will a Command Station suite my needs?
2003-06-04 by biz
>Interesting. My recollection was that the "jobs" on the Yamaha were more
>sophisticated than what's possible under Pattern Edit, but it's been a
while
>since I've looked at it (and yeah, it did seem quirky).
Yes, those are relatively more useful than the xl-7, but if you have the
musical skill, it's usually just easier to play the new version in again on
either beast.
>The lack of a useable realtime grid edit and the weak arpeggiator basically
>disqualified the Rm1x from live use in my mind.
Yes, realtime recording is not what it's good for.. However, the fact that
you have 16 sections laid out in front of you, along with harmonizing and
effects means makes it easier to layout and play with the overall song
structure, or switch between back like they were sampled grooves.
bIz
Sent: Wednesday, June 04, 2003 12:59 PM
sophisticated than what's possible under Pattern Edit, but it's been a while
disqualified the Rm1x from live use in my mind. The Play FX are kinda cool
but don't make up for the other things. I've also heard it hiccups when
switching songs, which may not matter for a lot of people but is an issue if
you're playing a continuous set (DJ-style).
I think for editing and finalizing tracks you can't beat a large monitor and
a
software sequencer, but for composition and performance I prefer hardware.
Direct Pattern Access, XMIX, and good arpeggiators are very central to my
working method (as you know from the thread over on livepa.org), which is
why I like the XL.
XL cf. RM1x was Re: Will a Command Station suite my needs?
How so? Aside from the MIDI fx like harmonizing and velocity offset, doesn't
the XL do all the same things? Not arguing, curious. The interface just seems
more immediate to me on the XL, but that's obviously subjective. Or are you
talking about the LCD?
Re: [xl7] XL cf. RM1x was Re: Will a Command Station suite my needs?
2003-06-04 by biz
The xl-7 can only lays out the 16 tracks at once - the rm1x also lets you select from a bank of 16 patterns at once.
If you use the 'trigger patterns' command on the xl-7, but this only lets you access one set of sixteen, instead of all of them. And there's no 'breakbeat' switching.
bIz
http://www.groovetronica.com - "Well, it hasn't made it into our playlist, I'm afraid. It's summer so there are no djs here to listen to and play music, so we're just playing automated music right now."
  Sent: Wednesday, June 04, 2003 1:35 PM
  Subject: [xl7] XL cf. RM1x was Re: Will a Command Station suite my needs?
RE: [xl7] Re: Will a Command Station suite my needs?
2003-06-04 by Stu
From what I can tell, the RM1x is much better for editing sequences,
especially as you have a bigger screen to see what you doing for starters...
It's also very good for chopping up loops and remixing tracks in realtime,
in ways you just couldn't do on the XL-7. Mind you, it depends on what
you're trying to do musically...
As regards the hiccups when you switch songs... if you set it up right then
it don't hiccup. Basically, it sends a whole load of setup info over midi
when you change songs, such as program change, bank select, volume, pan,
sustain pedal off, etc for every channel, which is a *lot* of data. There is
an option to switch this off, which solves the problem - if you still want
to send this info, then just insert the bits you want into the start of your
patterns.
The arp sucks - especially as you can only use it on patterns that you've
already recorded, and not the midi input.
Someone said in another post that they couldn't change a pattern's length
after they had recorded it... I've had no problem doing this and do it all
the time...
At the end of the day, I think it depends on what sort of music you do
whether an XL-7 or RM1x is best for you.
Stu
  Sent: 04 June 2003 21:00
while
basically
if
and a
  why I like the XL.
> the time...
That was me- and it was a while ago... but were you
shortening it or lengthening it?
AIM: IMFDUP
2003-06-04 by Stu
Both. Earlier today I changed a pattern from 8 to 32 bars, and at the same
time shortened a phrase from 8 bars to 2 bars.
I've also made phrases longer and patterns shorter... Most of my tracks have
loops of differing lengths running alongside each other and I've never run
into any problems doing so.
Stu
  Sent: 04 June 2003 23:10
  Subject: RE: [xl7] Re: Will a Command Station suite my needs?
  > the time...
  AIM: IMFDUP
Huh- well that was specificlaly my issue- having one
4-bar track looping while another 32-bar track played
out.
Maybe I just wasnt using it correctly.
AIM: IMFDUP
2003-06-04 by Stu
I think the trick is to set the loop length to the length you want the
phrase you're currently recording to be... If you want to record a 4 bar
loop over a 16 bar bar loop, you have to set the length to 4 bars. If you
leave the loop length at 16 bars and just record for 4 bars, you end with a
16 bar loop that plays for 4 bars followed by 12 bars of silence, if you see
what I mean.
I can understand why you think it can't do this, cause I seem to remember it
saying in the manual somewhere that you couldn't change the loop length once
you'd recorded a phrase, but it looks they were either wrong or talking
about something else...
Stu
  Sent: 04 June 2003 23:59
  out.
  AIM: IMFDUP
2003-06-05 by sincultura13
Hey Thanks! This has all been really informative!  I already have
ableton in my PC and is an awesome piece of software. I use it more
to tweak beats, sync stuff, and try ideas quick. I don't know how it
would react to whole songs, though.
I have a couple questions about what was posted...
"The lack of a useable realtime grid edit and the weak arpeggiator
basically disqualified the Rm1x from live use in my mind. The Play FX
are kinda cool but don't make up for the other things."
>>> I don't make techno-like music so I have no use for the
arpeggiator... The editing of midi loops is something I could use as
I play "live" from a keyboard most things... Both machines let you
record live things while what you already have is playing back,
right? What exactly is the realtime grid edit? And the play FX? This
are all new terms to me....
"> However, the fact that
harmonizing and
song
you
lets you
no 'breakbeat'
switching."
>>>So the XL-7 has access to 16 fragments composed of 16 tracks while
the RM1x additionally lets you access individual phrases on top of
the song fragment? What is this "Breakbeat" switching?
You know what, from what I'm gathering here these machines might
actually help me organize my ideas! I might not get dazzled with all
the information at once like on the arrangement screen in logic...
2003-06-05 by Aaron Eppolito
--- sisincultura <sisincultura@...> wrote:
> I don't make tetechnoike music so I have no use for the ararpeggiator
Arps aren't just for techno music.  They can make very evolving pads,
interesting effects, and all sorts of other cool stuff.
> Both machines let you record live things while what you already have
> is playing back, right?
Don't know about the RM1X, but the XL-7 was specifically designed to
minimize the need to EVER come out of record or press stop.  You can
even save while recording if you want.
Think TR-808 style edit.  16 buttons corresponding to 16 16th notes.
> The xlxl can only lays out the 16 tracks at once - the rm1x also lets
Huh?  With the XL-7 you have access to EVERY pattern in the box,
ququeueablen rerealtimeith NO hiccup, even with program changes, arps,
FX, etc.  I've played with the Yamaha sequencers (RM1X, Motif, RS7000)
and they all hiccup badly in my opinion, even between the 16 "armed"
patterns.
-Aaron
Do you Yahoo!?
Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
http://calendar.yahoo.com
Wow, did yahoomail spell check mangle that post...
  queueable in realtime with NO...
along with other more decipherable errors...
Do you Yahoo!?
2003-06-05 by Stu
As I explained in another post, the 'hiccups' are due to the machine not
being set up correctly... It is quite possible to change between patterns
and songs without glitches.
Stu
  Sent: 05 June 2003 02:43
  patterns.
  -Aaron
  Do you Yahoo!?
