Expanding the XL-7
2003-05-26 by Jacob Talkington
Soooo do we just open it and add it? How's this work? I didn't see anything in the manual (granted I didn't look too had) about adding new ROMS.. /.j
2003-05-26 by Patrick Dohman
Unplug the beast turn it upside down there are eight screws four along the top four along the bottom remove those at this point you will have two pieces be careful because they are connected by a couple of cables but you should have enough play to lay them down next to each other you will see the simm slots waiting for you at least one will be used if you look close it will have the name of the rom on it. Place you're your new rom in one of the empty slots it shouldn't matter witch one too much unless it the flash ram but to keep things tidy use the one next to the existing rom. Repeat the steps in reverse and your done. I understand the TSCY rom has extra presets for download on Rob Papen's website you may also want to copy the rom bank to one of your user banks so you muss with them. By the way the grid record knob input feature in 2.0 is pretty neato it reminds me of an analog sequencer. :-) Later Patrick
-----Original Message----- From: Jacob Talkington [mailto:anomaly10@...] Sent: Sunday, May 25, 2003 9:19 PM To: xl7@yahoogroups.com Subject: [xl7] Expanding the XL-7 Soooo do we just open it and add it? How's this work? I didn't see anything in the manual (granted I didn't look too had) about adding new ROMS.. /.j Yahoo! Groups Sponsor ADVERTISEMENT <http://rd.yahoo.com/M=244522.3313099.4604523.1512248/D=egroupweb/S=1707 709865:HM/A=1595053/R=0/*http:/ashnin.com/clk/muryutaitakenattogyo?YH=33 13099&yhad=1595053> Click Here! <http://us.adserver.yahoo.com/l?M=244522.3313099.4604523.1512248/D=egrou pmail/S=:HM/A=1595053/rand=760195094> To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed]
2003-05-26 by M2
http://groups.yahoo.com/group/xl7/files/Command%20Station%20Info/ Also check the link above. It's been in the files section for awhile now. Enjoy. --- In xl7@yahoogroups.com, Patrick Dohman <pdohman@c...> wrote: > Unplug the beast turn it upside down there are eight screws four along > the top four along the bottom remove those at this point you will have > two pieces be careful because they are connected by a couple of cables > but you should have enough play to lay them down next to each other you > will see the simm slots waiting for you at least one will be used if you > look close it will have the name of the rom on it. Place you're your new > rom in one of the empty slots it shouldn't matter witch one too much > unless it the flash ram but to keep things tidy use the one next to the > existing rom. Repeat the steps in reverse and your done. I understand > the TSCY rom has extra presets for download on Rob Papen's website you > may also want to copy the rom bank to one of your user banks so you muss > with them. > > > By the way the grid record knob input feature in 2.0 is pretty neato it > reminds me of an analog sequencer. :-) > > > Later > Patrick > > > > > > > > -----Original Message----- > From: Jacob Talkington [mailto:anomaly10@h...] > Sent: Sunday, May 25, 2003 9:19 PM > To: xl7@yahoogroups.com > Subject: [xl7] Expanding the XL-7 > > > Soooo do we just open it and add it? How's this work? I didn't see > anything in the manual (granted I didn't look too had) about adding > new ROMS.. > > /.j > > > > > > Yahoo! Groups Sponsor > > > ADVERTISEMENT > > <http://rd.yahoo.com/M=244522.3313099.4604523.1512248/D=egroupweb/S=1 707 > 709865:HM/A=1595053/R=0/*http:/ashnin.com/clk/muryutaitakenattogyo? YH=33 > 13099&yhad=1595053> Click Here! > > > <http://us.adserver.yahoo.com/l? M=244522.3313099.4604523.1512248/D=egrou
> pmail/S=:HM/A=1595053/rand=760195094> > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! > <http://docs.yahoo.com/info/terms/> Terms of Service. > > > [Non-text portions of this message have been removed]
Ah, thank you! (and to the previous responder as well!) --- In xl7@yahoogroups.com, "M2" <mmcquay@s...> wrote: > http://groups.yahoo.com/group/xl7/files/Command%20Station%20Info/ > > Also check the link above. It's been in the files section for > awhile now. > > Enjoy. > --- In xl7@yahoogroups.com, Patrick Dohman <pdohman@c...> wrote: > > Unplug the beast turn it upside down there are eight screws four > along > > the top four along the bottom remove those at this point you will > have > > two pieces be careful because they are connected by a couple of > cables > > but you should have enough play to lay them down next to each > other you > > will see the simm slots waiting for you at least one will be used > if you > > look close it will have the name of the rom on it. Place you're > your new > > rom in one of the empty slots it shouldn't matter witch one too > much > > unless it the flash ram but to keep things tidy use the one next > to the > > existing rom. Repeat the steps in reverse and your done. I > understand > > the TSCY rom has extra presets for download on Rob Papen's website > you > > may also want to copy the rom bank to one of your user banks so > you muss > > with them. > > > > > > By the way the grid record knob input feature in 2.0 is pretty > neato it > > reminds me of an analog sequencer. :-) > > > > > > Later > > Patrick > > > > > > > > > > > > > > > > -----Original Message----- > > From: Jacob Talkington [mailto:anomaly10@h...] > > Sent: Sunday, May 25, 2003 9:19 PM > > To: xl7@yahoogroups.com > > Subject: [xl7] Expanding the XL-7 > > > > > > Soooo do we just open it and add it? How's this work? I didn't > see > > anything in the manual (granted I didn't look too had) about > adding > > new ROMS.. > > > > /.j > > > > > > > > > > > > Yahoo! Groups Sponsor > > > > > > ADVERTISEMENT > > > > > <http://rd.yahoo.com/M=244522.3313099.4604523.1512248/D=egroupweb/S=1 > 707 > > 709865:HM/A=1595053/R=0/*http:/ashnin.com/clk/muryutaitakenattogyo?
> YH=33 > > 13099&yhad=1595053> Click Here! > > > > > > <http://us.adserver.yahoo.com/l? > M=244522.3313099.4604523.1512248/D=egrou > > pmail/S=:HM/A=1595053/rand=760195094> > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@yahoogroups.com > > > > > > > > Your use of Yahoo! Groups is subject to the Yahoo! > > <http://docs.yahoo.com/info/terms/> Terms of Service. > > > > > > [Non-text portions of this message have been removed]
2003-05-27 by erik_magrini@Baxter.com
Look harder....
(you guys are getting lazy!)
"Jacob Talkington" <anomaly10@...>
05/25/2003 09:19 PM
Please respond to xl7
cc: Subject: [xl7] Expanding the XL-7 Soooo do we just open it and add it? How's this work? I didn't see anything in the manual (granted I didn't look too had) about adding new ROMS.. /.j To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
2003-05-27 by Jacob Talkington
Yeah - this one got answered earlier both on here and with a screwdriver ;) Thanks! (And for the note-unsticking tip as well). /.j --- In xl7@yahoogroups.com, erik_magrini@B... wrote: > Look harder.... > > rEalm > (you guys are getting lazy!) > > > > > > "Jacob Talkington" <anomaly10@h...> > 05/25/2003 09:19 PM > Please respond to xl7 > > > To: xl7@yahoogroups.com > cc: > Subject: [xl7] Expanding the XL-7 > > > > Soooo do we just open it and add it? How's this work? I didn't see > anything in the manual (granted I didn't look too had) about adding > new ROMS.. > > /.j > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
