XL7 Thru A Compressor?
2003-05-23 by rayisfab
I'm using the XL7 with Sonar and softsynths.  I'd like to find out
whether other XL7 users output their XL7 through a frontend
compressor before recording it to harddisk.  I'm making dance music
(techno/trance etc. etc.).
I'm looking to buy a compressor such as TLAudio's Fat 1 or FMR Really
Nice Compressor 1773 to compress and warm up the XL7 stereo output.
The compressor will be patched into the RME Multiface.  I want to get
a nice hot signal onto disc and not have spikes.
Do any of you compress the XL7 sound?  If so what do you use or think
is the best sounding frontend?  I've spent a ton on the RME so I
can't afford the really high end compressors.
I've also thought of using compressor plugins on the XL7 stereo input
inside the computer but don't know how to set this up in Sonar or
with the RME mixer.  Is it easier to use an outboard compressor
instead?
Any ideas/experiences on this subject appreciated. :)
RE: [xl7] XL7 Thru A Compressor?
2003-05-23 by ByronIV
I personally wouldnt reccomend doing it (but each to his own)...BUT I have
heard that the RNC is a great compressor indeed, if you did it extremely
lightly it may just be enough to take out spikes, but at the same time it
may very well harm the sound if you're recording all the tracks at once. If
your doing the racks seperately, then go for the gold, I'm sure that would
spice up the sound quite nicely (Really Nice, I'm sure, hehe). But, by doing
that, at least for me, kind of ruins the entire reason of having an RME (I
have a digi96 with the expansion board). I bought it so I wouldn't HAVE to
record all of my tracks seperately anymore, so now I need like FIVE
compressors (or two bi-linear stereo and a mono one) in order to get
seperate compression on all my stuff. Arg....
I myself, don't have a real compressor, since I have no money, although I
have that behringer half/fake tube compressor in my studio from time to
time, and may own it soon (as gay as it can be, if I get it, those tubes are
getting replaced!). I usually use software compression, although I would
severely reccomend using real hardware instead. I only use software since
it's what I have. T-racks is great, but is not a plugin, so it can get
tedious using it on seperate tracks since you can't hear it in conjunction
with the rest of the them. Overall, you can't beat the sound of a nice warm
REAL tube compressor, but from what I hear, that RNC can come pretty close
to compression heaven.
Cheers
ByronIV
> -----Original Message-----
> From: rayisfab [mailto:rayisfab@...]
> Sent: Friday, May 23, 2003 12:19 PM
> To: xl7@yahoogroups.com
> Subject: [xl7] XL7 Thru A Compressor?
> instead?
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.476 / Virus Database: 273 - Release Date: 4/24/2003
Outgoing mail is certified Virus Free.
Re: [xl7] XL7 Thru A Compressor?
2003-05-23 by biz
If you are recording at 24 bits, just turn down the volume. You have more
than an order of magnitude more dynamic resolution than you do at 16 bits. I
know of more than one producer that is doing this for vocals - the most
dynamicly fluctuating instrument that you can put a mic to, and then
compressing after the fact. How else do you think digital compression units
(TC Gold Channel etc) do this? (This is not an endorsement of outboard
digital compressors :>)
>BUT I have
That depends what you consider 'harm'. For the vast majority of music, it is
customary to compress the entire group of tracks together, and even
subgroups. If anything, you will change your sound more by compressing
tracks separately - all the tracks will now sound 'compressed'.
If you are happy with the mix (or sub mix, if there is going to be other
stuff to do), and want it to be compressed, then sure, compress it. Don't do
it just to 'get it in the pc'.
>> If
doing
getseperate compression on all my stuff. Arg....
Nah, just turn them down. Like I said, if you are recording at 24 bits...
are
>getting replaced!).
Behringer gets a bad rap - they make great gear for the money. I haven't
heard their 'faux-tube' gear, but I don't think I'll be impressed. I don't
think all that much their solid state compressors either - that I have
direct experience with.
It really depends what you have available. Don't be fooled by 'pro'
interveiws - they are comparing software to hardware costing ten or twenty
times as much. Your behringer isn't going to sound better than your
Rennaisance compressor, or PSP stuff.
Each to their own - I can't stand T-racks. On my music, it pumped and
breathed like a cheap stomp box. Try the PSP audioware stuff, or the Waves
Rennaisance compressor.
For extra niceness, try using more than one compressor set in series, with
moderate settings on each, instread of one with a drastic setting. As well
as sounding smoother, this allows you to create more complex dynamics
curves, as well as mixing and matching compressor plugins for tonal quality.
Note: the RNC won't "warm up your sound". It's designed to be a transparent
and invisible as possible - the opposite of 'warming up your sound". It is
nice, though I haven't heard it much. I'm looking to upgrade my preamp to an
RNP and RNC combo right now myself.
On another note, heres' a cool vocal recording tip -
- mult the send from your preamp to your compressor, and send it straight
into your pc on a second channel, so you have one channel compressed, the
other uncompressed.
- record both inputs to separate tracks, with the uncompressed track muted,
so that you don't have to hear it. Since you are compressing the vocals
coming in, you can monitor everything at a nice level without clipping
anything, or screwing with your gain structure to hear what you need, >and<
you've got a good vocal sound right from the start. Drop the level on the
uncompressed version, to make sure you get all the peaks, a lot (remember
that 24 bits...), especially if she's a belter :>
- now, in addition to the compressed performance, you have an uncompressed
tracking of the same performance. This is usuefull in a number of ways
    - it's your backup in case you over/under compressed - no ruined track!
    - you can run it on top of the compressed track to give it more range,
while maintaining the general level of the compressed track
    - you can run it through a difference compressor, for a different sound
    - you can use it for effects - especially ADSR controlled ones, like
filters or wahs - since it still contains the strong dynamic range of the
original recording, and will be more responsive to this. This is especially
cool when you track it with the compressed track. Radical EQs also work,
since the 'effect' track will only poke it's head up on the louder parts.
I'm sure this would also be cool on all kinds of acoustic instruments -
guitars etc.
good luck,
bIz
groovetronica.com - "The beats are ok, I suppose, but the vocals sound like
some vintage jazz singer from my dad's record collection. Definitely not for
me."
Are you still here? The message is over. Shoo! Go away!
2003-05-27 by erik_magrini@Baxter.com
Personally I think that if you're going to be recording to Sonar anyway,
you might as well just use a software compressor after the fact.
Especially if money is tight, since there are a ton of freebie compressors
out there that will do the job.  I can't tell you the specifics of how to
use Sonar since I'm not too familiar with it, but after you've recorded
the audio you would want to assign a comp plug in as an insert effect on
that track.
Compression can make a huge difference, but it's subtle effect and if
overused can ruin an other wise good sounding tune.  Take your time and
experiment, and try to find some compressor tutorials on line.
with the RME mixer.
2003-05-27 by jibarosoul@aol.com
I insert a DBX 166xl that then goes thru an ASHLEY 16 band graphic stereo EQ
 and finally to a KORG KP2. I only use my MP-7 in the studio right now so
portability is not an issue. This insert is setup to mainly process my drums and
sometimes bass but that's it. I sometimes even bypass all of it if its not
really being changed a whole lot before I go into Pro-Tools. Here is my
opinion.....
Upside: Adds nice punch to all my drums. Settings vary greatly based on song
and sound selection but good over all on kicks and snares. Instant tailoring
of sound at my fingertips. Kaoss pad adds nice delays and verbs splashes and
dropouts. Drum patterns sound more dynamic.
Downsides: Some noise when kaoss effect send is turned up. Not portable
really. Can sound harsh on some hi-hats and shakers when compressed to hot.
Compressor can be confusing to someone not used to it. Lacks warm tone of some tube
compressors. Sound can be copied in plugins sometimes. I would like to get a
second tube compressor such as a TL Fat Man or Drawmer tube station and A/B the
sound between the DBX 166xl
