Red Sound Micro Sync
2003-05-22 by erik_magrini@Baxter.com
Yes, the way the connections on Micro Sync have to be achieved is one of
it's unfortunate downsides, though there are ways around it.  The basic
premise is that the MS needs to have an audio signal being fed to it, and
from this audio signal it detects the tempo and generates the MIDI clock
your 505/R8 will use as it's clock source.  The problem, is that if you're
just sending it a signal from the main outs of the DJ mixer (or recording
outs), you're also sending it the audio from 505/R8 as part of that
signal. Thus, you get sort of a feedback loop, where you're trying to
detect the BPM of the records to sync the 505 to, but you're also using
the signal of the 505 as a source as well.  So in this situtation not only
is the 505 receiving a clock signal, it's also part ot the audio
generating it!  So it's not a audible squeeling, cover your ears type of
feedback, but an issue with the sync.
There's two ways around this, depending on the situation.  If you're in a
situation where you can use an external mixer, then you can connect it via
the diagrams on the Red Sound page and you're good to good. Unfortunately,
this is rarely possible in a club setting, so you have to use another
method.  I personally use the effects loop sends on the DJ mixer, and feed
these to RedSound, and then set channels 1&2 to use the effects loop via
the switches on the mixer panel.  As long as you don't send the third
channel the 505 is on to the effects loop, you should be fine.  This is
also nice, because most DJ mixers have the effects loop post fader, so you
won't get any weird syncs happening while your buddy is cueing up his next
record (since that channel's fader or the crossfader will be lowered, thus
nothing will go out the effect send).  Works fine in use, and you can use
the effect send knobs on the mixer to govern the levels of the audio
signal going to the MS.  The MS is kinda picky about the audio levels
going to it (too loud or quiet and it doesn't work well), so this is very
nice.  BTW, the MS has an LED that changes colors to let you know the
strength of the input signal, so no worries there.
Keep in mind it's not perfect, the MS will still need to be adjusted for
some records (the tempo will be right, but the beat is off), so you need
to have it where you can reach it still.  Just FYI.
Questions?
   Realm, I know you have experience with the RedSound microsync. I
am getting ready to purchase this so a friend and myself can rock
decks and drums. I just wanted to know how is this thing connected to
a basic dj setup?... 2 technics, a 3 input mixer and a 505/R8. I have
the drums going into the line input on my third channel.
The pdf said something about a sub-mixer and it confused me. Do I
need 2 mixers before I go into the club's board? Thanks.
dj skurge
Re: Red Sound Micro Sync
2003-05-22 by djskurge
Excellent clarification, thanks. The only question I really have left
is how tight is the sync? Does it stay locked at least 90% of the
time? The reason I ask is because my buddy and I actually kind of
live remix, where I do fast techno/electro edits on the decks and he
rocks the drums 90% of the time, so what this means is I kill the
bass on most of my mixes. Does that lack of bass signal screw up the
micro?, since its getting the signal off my decks? Basically, I need
something to keep my attention off trying to lock with the 505/etc.
all the time, and focus more on my mixes. If I can do this most of
the time, then I'm all for buyin this thing. Thanks again.
dj skurge
"Keep in mind it's not perfect, the MS will still need to be adjusted
for some records (the tempo will be right, but the beat is off), so
you need to have it where you can reach it still. Just FYI."
Questions?
RE: [xl7] Red Sound Micro Sync
2003-05-22 by Stu
Hi erik,
How do you find your MS's timing when you don't have any audio signal being
fed to it? Mine is flakey... I use it to drive an E6400 Ultra, and I can
constantly hear small tempo changes going on when I've got bpm synced
effects running (it's especially noticeable with delays, coz the delay
signal gets detuned slightly if the sync changes, causing a flanging
effect)... If I use my rm1x to generate midi clock, the timing is solid. So
it's definitely an issue with the MS...
Stu
  Sent: 22 May 2003 20:22
  Subject: [xl7] Red Sound Micro Sync
  Questions?
  dj skurge
        Yahoo! Groups Sponsor
Re: [xl7] Re: Red Sound Micro Sync
2003-05-23 by erik_magrini@Baxter.com
>>>Surprisingly very good.  You might hear it drift slightly once in
awhile, but it's veryg ood at getting the tempo. <<
Does it stay locked at least 90% of the time?
>>>Yep. Occasioanlyl you may need to 'nudge' it a bit, but they have
dedicated buttons for this, so it's easy to do.<<<
>>>It doesn't just use the bass, it read treble and midrange too.  If you
want kill the sound of the decks, the Ms will still stay at the same tempo
until it detects new audio to read, so no worries there.  Or you can put
it into 'freewheeling mode' which basically pauses the unit from detecting
new timing info and accidentally changing the tempo say during a drop. <<<
Basically, I need something to keep my attention off trying to lock with
the 505/etc.  all the time, and focus more on my mixes. If I can do this
most of the time, then I'm all for buyin this thing. Thanks again.
>>>Yeah, it's not something you can just plug in and forget about, I wish
it was.  Most of the time it's fine, but like I said once in awhile you
need to adjust it slightly to match the beat, even though the tempo is
correct, or nudge it slightly.  I'm in the same boat as you, and this is
by far the best device I've found to do what we want.  It's not ideal, but
it works very well 95% of the time.   I say buy it fom a larger chain with
a good return policy, jsut in case it doesn't work the way you like. <<<
Well, it needs an audio signal to work, so if you're not feeding it any
audio, then what's the point?  You can manaully enter the tempo via the
incremetn buttons and then press start.  Maybe I'm not understanding your
question?  If you don't want it changing the tempo once you have it
locked, just put it in freewheeling mode.  I do this most of the time for
best results.  I'll use it to get the tempo of the record, then freewheel
it the rest of the track.  It's pretty rare to get tempo fluctuations on
the record itself, so once it has it, the tempo should change until you
change records.  Then I take it out of FW mode until it sync again, then
FW, etc....
being
So
2003-05-23 by Stu
Hi Eric,
The reason I run it with no audio signal is coz I don't always sync to
external audio, and it's not really practical to change the settings on my
other kit in the middle of a gig to sync to another clock source, so I just
use the MS without an audio signal...
Anyway, you obviously don't have the same fluctuations I have, or you're not
using your MS in a way that they're noticeable...
Out of interest, what firmware do you have in your MS? Mine is 2.04.
Thanks for replying anyway,
Stu
  Sent: 23 May 2003 13:32
  Subject: RE: [xl7] Red Sound Micro Sync
  FW, etc....
  being
  So
              ADVERTISEMENT
