For those of you that have hum in the headphone socket only, be sure
to try this one!! After months of trying everything and finally
giving up, I found this post. Upon loosening the nut a little bit all
the buzzing has dissapeared. Note that now the nut is quite loose, and
easily turned by hand. I wouldn't want to transport the unit without
tightening it again.
Thank you rEalm!
Ken
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> Try loosening th nut that holds the headphones socket to the case
'just a
> little bit'. Not enough to make it loose at all, but enough to relieve
> any pressure that might be causing the socket to short with the case,
> resulting in a hum.
> rEalm
