Drum methodology
Drum methodology
2003-05-07 by erik_magrini@Baxter.com
Hmm, already done this few times, but here goes (this is only MY
methodology, I'm sure there's tons more)...
- I typically start out by assigning one of the prc Presets to each of the
1st four tracks.  IE, Track 1 gets a prc:Kicks Preset, Track 2 gets a
prc:Snares Preset, Tracks 3 and 4 share a prc:Hats Preset.  My default
000:0 Pattern actually has these assigned already to save me time.
- Next I save each preset as a User preset based on the Pattern name.  For
instance, on my song Composite Blue, I'd have Blue BD, Blue Snare, Blue
HH's, etc.  That way I can tweak the Presets and save the results very
quickly once I start writing, without having to worry about overwriting
another user location.  This is just prep work to speed things up later on
when I'm in the groove and don't want to stop for XL-7 housekeeping
duties.  :)
- Next I begin with a basic BD and Snare pattern using Grid Record based
on the type of song I'm doing.  For a 4/4 song, this would be BD's on the
1,5,9, and 13, with Snares on the 5 and 13.  For breaks stuff, it would be
BD's on the 1 and 11, Snares on the 5 and 13.  This is just something to
get me started, a template to play over if you will.  All of this is in a
1 measure pattern still.
- The next step is to work on layering the BD and Snare presets.  I go
into the Save menu, and copy the Layer and Cords from Layer 1 to Layer 2
on both the BD and Snare Presets, then Save them.  Next I'll start playing
with the Transpose settings of Layer 2 in both Presets, which effectively
changes the sample used on that layer since I'm using a prc Preset
dedicated to those type of sounds.  I'll keep playing with this, changing
the Amp Vol between the two layers until I get something full and clear
sounding that fits what I'm trying to do, then I save.
- Next I'll Extend the Pattern to 8 measures, and start working on the
actual programming of notes.  I tend to use Grid mode to get the rough
ideas down, from there I use Note List editor to add subtle variations in
velocity as needed.
- I'll probably start doing the HH stuff too at this point.  Closed HH's
go on track 3, Open HH's go on Track 4.  I sometimes play them in manually
via the key pads or if I have a specific idea I may just Grid Record them
too.  Once I get a HH pattern I'm happy with, I'll use the Save menu to
copy the layer and cords for this Preset too, though I don't always select
a new sample in Layer 2, I'll just use a duplicate of Layer 1.  As always,
it depends on the track.
- After I'm happy with the basics of the drum tracks, I apply a slight
amount of Shuffle quantize to loosen things up.  I find that this setting
[Res 16, Amnt 60-65, and Swing 53-55] works the best for most of my stuff.
 For some of my breaks stuff, I might use more swing, hard techno gets
less.
- That's about it for the basics, after this I'll add other percussion
sounds for more variety, probably some crash cymbals at the start of the
measure and maybe every 8th measure, etc.  Just depends on what I'm trying
to do.
Speaking of which, rEalm, can u post the methodology for making drum
patterns
out of waveforms.  i remember awhile back u posted the means to create
drums
(basslines?) out of waveforms and it sounded really dope.  thanks..
Re: Drum methodology
2003-05-07 by drewaight1
rEalm you are so fukking fresh.
I wish someone would start a rEalm religion.
Re: [xl7] Drum methodology
2003-05-07 by biz@groovetronica.com
Yes. Thanks for this excellent toilet paper, erik.
By toilet paper, I mean article that I will print out and put in the folder next to my bathroom, for extended reading :>
bIz
  Sent: Wednesday, May 07, 2003 9:51 AM
  Subject: [xl7] Drum methodology
  duties.  :)
  velocity as needed.
  less.
  to do.
  patterns
  drums
        Yahoo! Groups Sponsor
Re: [xl7] Re: Drum methodology
Are you being sarcastic?
drewaight1 <drewaight@...>
05/07/2003 02:15 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Drum methodology
Nope. I dont know what bIz is talking about. I fukkin printed that
post. I especially like the Idea of naming your presets with the song
name, my user presets are a mess, I dont even know which ones ive
saved.
The XX-7 is very complicated, and walk-thrus are totally helpful IMHO.
I too, printed that out.
As I said, I keep it next to my bathroom, with all the other important tips I have printed out. Not everyone writes a tip worth putting in that folder.
You guys take yourselves >way< too seriously.
I'm warning you - Don't make me get out the poll!
bIz
  Sent: Wednesday, May 07, 2003 3:05 PM
  saved.
2003-05-08 by erik_magrini@Baxter.com
Yeah, drK pointed this one out to me when I first got the XL-7, and it
helps a lot.  I save all of my presets with some reference to the Pattern
they are used in, and I save all of my presets seperately for each pattern
too.  That way I can fire up any pattern and know I don't have have to
worry about tweaking and saving a Preset that's used in another Pattern.
Here's another housekeeping tip I use a lot.  Make yourself a spreadsheet
that has cells for all of your presets.  IE, 000:0-127:0, 000:1-127:1,
etc.  Don't worry about filling in the Preset names, just make a table
that has the actual Preset numbers listed.  With this in hand, you can go
through each Pattern and cross out the Preset numbers being used on each
Track.  I find it easiest to put the view on Preset, then just use the
Channel/Track up and down buttons to scroll through each track (check your
mute buttons to see which tracks actually have data on them too).  Anyway,
this allows you to cross out all of the Presets that you're actually
USING, leaving the Presets that aren't saved as part of Pattern uncrossed.
 Once I have gone through all of my Patterns, I'll then copy the default
Preset to all of the uncrossed User locations.  This way, I get rid of
Presets I'm not using, and then when i am working on the Xl-7 and need to
save a Preset, I can just start at location 000:0 and scroll until I see
the next location where the Default Preset is stored.  The procedure only
takes 20-30 minutes depending on how many Patterns you have.  A good
project for those days when you're just not wanting to do music....
saved.
2003-05-08 by Wesley D
Someone mentioned turning waves into drum samples, or vice versa.
ReAlm know how to do this?  Do tell, do tell, I didn't catch it.
peace, Wesley D.
www.evolbeats.com
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
You can only do it with an Emu Ultra smapler, and the Emu Flash Rom. There
is no other way and there never will be.
peace, Wesley D.
www.evolbeats.com
Do you Yahoo!?
well damn...
I always knew there something more to those things than meets the eye.  Definitely on my list of things to aquire.
Any particular one you'd recommend.
The 6400 Ultra was my pick. later, Wesley D.
www.evolbeats.com
Do you Yahoo!?
Depends on your needs, be sure to check the Emu site, they have some
refurbished ones for cheap...
"Wesley D" <Serfiss@...>
05/08/2003 02:45 PM
        cc:
        Subject:        Re: [xl7] Re: Drum methodology
well damn...
www.evolbeats.com
Do you Yahoo!?
