linking knob functions for different presets
2003-04-19 by honkeyhindu
linking knob functions for different presets..is this possible ..say
i want to controll the  filter of ch1 and the amp attack of ch 2 with
the same or even different knobs,heh..  at the same time ..without
pre recording it ...
Re: linking knob functions for different presets
2003-04-19 by joesapo
I think what you want is the Realtime Controller menu screen under
the controllers menu.  It looks like a:00 b:00 c:00 d:00 and so on.
These numbers correspond to cc#'s for the Quick Edit knobs in each
preset, so setting A:22 will make all presets have the cc:22 for
their filter cutoffs.  (Be sure to look up some unused CC numbers in
the manual first.)  What I do is set the programmable knobs 13-16
with filter cutoff, Q, volume(cc7) and pan(cc10) set to the basic
channel, so whatever is the current selected preset gets controled by
all those knobs.  The rest of my programmable knobs are routed to FX
and pads on the B channels.  Hope this helps.
sapo
possible ..say
with
thanks ..
on.
in
by
FX
> sapo
> possible ..say
> with
time ..without
Re: [xl7] Re: linking knob functions for different presets
2003-04-20 by Wesley D
Ok, what I'm wondering here, is:
While in sequencer mode, is it possible to have knobs routed to multiple channels?
To elaborate, does the XX-7 allow you to modulate multiple channels at once?
An example would be A - filter channel 1
B - filter channel 2
C- filter channel 3.....
and so on....... I'm currently using an XL-1, I'd like to upgrade to an Xl-7, and this would is pretty important to me.
Thanks in Advance, Wesley D.
www.evolbeats.com
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
2003-04-20 by Aaron Eppolito
Yep.  There's a "programmable" knob mode, accessible with a front panel
button.  In it, each knob can be assigned an independent channel,
controller number and internal/external status.
-Aaron
> multiple channels?
> at once?
> www.evolbeats.com
Do you Yahoo!?
http://search.yahoo.com
That is just insanely sweet!!!   I'm totally sold on this machine.  Think I'll keep my XL-1 anyway though.
Thanks!
Wesley D.
www.evolbeats.com
Do you Yahoo!?
2003-04-21 by erik_magrini@Baxter.com
Yes, in Program Mode for the knobs.
"Wesley D" <Serfiss@...>
04/19/2003 11:08 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        Re: [xl7] Re: linking knob functions for different presets
channels?
once?
www.evolbeats.com
Do you Yahoo!?
