dry sounds
dry sounds
2003-03-19 by crossfade78
dose anybody know if there is a way to shut of the verb that is
already on all the presets straight out of the box? this can be
annoying when recording. in most recording apps. the sound is
recorded dry then effects are added, right? this verb that they put
on fills up the mix with unwanted stuff. and one more thing, when
recording with the pads, i sometimes have a hard time getting a level
consistant pattern out because of the velocity sensitive pads. is
there a way to shut these things off like in a global type of way so
it will affect all of the sounds in all banks??? thanx
Re: [xl7] dry sounds
2003-03-19 by erik_magrini@Baxter.com
For your first question, you can set the effects to be controlled
in"Multimode" in the MIDI menu, then set all EFX Sends Amounts to 0
(Global Menu) for the track you're using.  Viola, no reverb.  Regarding
the pads, there's no way to turn them off globally.
crossfade78 <crossfade78@...>
03/19/2003 11:31 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] dry sounds
