LFO sync, please...
LFO sync, please...
2003-02-18 by pocketd@gmx.de
hope someone can help me, I`m trying to get a synchroniced LFO, so what I
tried was setting the LFO to free
run and a 8/1 clock sync in the LFO menue.
My pattern is 8 bars long, and what happens is quiet strange:
1. LFO don`t starts at zero as it should when I start the pattern
2. it starts at zero if the pattern is looping first time and stops after 6
bars
I tried to get it right by the clock modulations sources, but it seems they
retrigger always playing notes.
what`s going wrong?
thanx,
Christop
+++ GMX - Mail, Messaging & more  http://www.gmx.net +++
Bitte lächeln! Fotogalerie online mit GMX ohne eigene Homepage!
Re: [xl7] LFO sync, please...
2003-02-18 by drK
On 2/18/03 12:35 PM, "pocketd@..." <pocketd@...> wrote:
> Hi,
> bars
> what`s going wrong?
> thanx,
> Christop
What waveform are you using?  The reason I
ask is my recollection is that the initial starting value (phase = 0) is not
what I at least expected.  For example the pulse-type waves I believe start
at an on value and not zero.
Also is this repeatable every time you start the pattern from a full-stop?
Guessing here but the XX-7 likely keeps track of a bar count from the start
of sequencing (time=0).  Pausing the sequence, which is stopping without
returning the position to start, will not reset this position.  So (again
speculating) playing a one bar pattern four times followed by an 8 bar
pattern (whether paused or not between) will have the 8 bar pattern
"see" the LFO as if it was starting in mid-phase as the change in patterns I
do not believe restarts the LFO phases.
Again I am speculating.
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
2003-02-19 by pocketd@gmx.de
I used a sawtooth wave with the cord:
LFO+ -> Amp  +96 (initial vol.-96)
So what should happen with the synchronized LFO (8/1) is that it´s beginning
at zero and going up to the cord
amount.
Yes, and so far I really have to believe it`s a bug, it works using clocks
till 1/1 but as I go above that time,
the XX-7 seems to half the time in the beginning LFO, so if I choose a 2/1
sync the LFO starts at a value he
would be after 1 bar.
Yes, but I start at time 0 as I start the pattern from the beginning.
So (again
Ok, that could be, but in my experiment I do not switch patterns, just
playing one from the beginning.
I didn`t choosed a tempo track so far.
thanx,
Christo
