Missing controller options / arpeggiator? also beats/riffs
2003-02-12 by Erika <erika_ev1@yahoo.com>
First, the manual is pretty confusing. I'm having a hard time understanding how the different systems work together. I've got most of the basics.. But I was reading through the beats and riffs section. In order to activate them you set the triggers function to play beats under the edit controllers button, correct? I didn't have this option, unless it's a submenu that I am having trouble accessing. Also I didn't see an option to set the pedal command either under the controllers menu. I going as per the screens listed under the topic in the manual. Also, I'm having trouble figuring out how to set an arpeggio to a preset. I've tried using the master arppegiator, but all I get is a four on the floor and not an arpeggio. Grr.. I so want to learn this. Im going to update the OS tonight, I only have 1.0. Any help on these topics would be greatly appreciated..
