One Sneaky setup
2003-01-29 by erik_magrini@Baxter.com
Now, what if I got one of these two (Which is better) SuperNova2 Keyboard version or Virus KC5 Keyboard version >>>Depends on what you want. They both sound amazing, and do the analog emulation thing quite well. <<< If I get this set up, I'm going to need a sequencer, something I have no idea how to do on a PC. My question is, if I do this set up, can I use either of these keyboards as the controller for the Orbit3? If so, how will it work? >>>Yes, both of those keyboards will work as controllers (ie, you can play the virus and make it trigger sounds in the Orbit). You'll still be without a sequencer though, as neither keyboard has one. <<< Does this "1024 programs (256 User / 768 ROM / 128 Multi" Mean that the Virus has 1024 individual sounds? >>>Yes, and they're excellent. My vote would be for you to first get a Command Station so that you have a sequencer, not to mention a really good synth too. You can always add the cards from the Orbit3 later on if you really want, though I think you'll be quite surprised at the sounds that come with the XX-7's and maybe not want new cards right away. I would also suggest maybe one of the two synth you mentioned previously to compliment that, you can't go wrong with either, and you'll have way more synthesis power with both macvhines to ever get tired of the sounds. <<< <<< rEalm [Non-text portions of this message have been removed]
