patchcords
patchcords
2003-01-28 by Jean Kergutuil
hi all
I would like to assign via patchcords LFO to filter res... and i would like
to understand how to set up the amount on midi A (for example) of
"programmable knobs"....
any idea ???
(hope you understand me !! thx)
Re: patchcords
2003-01-28 by nifflas <nifflas@musician.org>
First, you use a patchchord, let's say #1 to route the LFO to filter
cutoff (resonance can not be controlled in realtime). Amount should
be zero. Then use patchchord #2 to route Midi A to patchchord #1 amt.
//Nifflas
--- In xl7@yahoogroups.com, "Jean Kergutuil" <jean.kergutuil@a...>
wrote:
> hi all
would like
> any idea ???
patchcords
2005-09-20 by malik
hi i am trying to send cc data via keys from my mp7. can i do this via
patchcrds?
looking in the patchcords menu it is at key+ -> c24Amt. i almost pisse
my pants when i srolled through and found these!!!
what does it mean?
Re: [xl7] patchcords
2005-09-20 by Aaron Eppolito
You can't send MIDI from patchcords.  No way, no how.  Ever.
c24Amt is CORD 24.  It is how you control the amount of one patchcord
with another patchcord.  An example of this is LFO amount, where an LFO
controls pitch on one cord, then a knob controls the amount of the
modulation on a different cord.
-Aaron
> via patchcrds?
> pisse my pants when i srolled through and found these!!!
> what does it mean?
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
Re: patchcords
2005-09-20 by malik
bummer..
patchcord
an LFO
> -Aaron
this
> > via patchcrds?
> > what does it mean?
patchcords
2009-11-03 by nedxl7
as much help as possible please on patchcords pleeeaase
2009-11-03 by Mauricio Balma
Man man man, you must be more specific. PATCHCORDS is huge......
Is the most complex programmation section so saying patchcords help please,..... won't be helpful.
There is a source, a parameter, and a destination, another parameter.
If you want LFO modulating the pitch
LFO1 -----to------ PITCH : +100
LFO1 is the source, PITCH the destination
There are 24 possible patchcords for each instrument inside a patch.
Let's suposse the previous one was on location 1.
You want to control that patchcord with a knob
So
LFO1----to------PITCH : 0
KNOB1-----to-----LOCATION 1 : +100
So please define what's your question, since things there, are not so easy, like the lags...
Sent: Tue, November 3, 2009 9:42:43 AM
Subject: [xl7] patchcords
2009-11-03 by Jack Pratt
EMU has provided a lot of help in the form of a manual. Why not start there - its pretty informative.
Sent: Wed, November 4, 2009 1:42:43 AM
Re: patchcords
2009-11-03 by steve_the_composer
I agree with what others have said so far: (1) be more specific on what you want to do with patchcords (and possibly let us know what you do and don't understand about patchcords) and (2) check out the manual--its pretty good in covering the basics and some intermediate aspects of patch cords.
Also, let me add a few other suggestions and a very basic tutorial (which you might be beyond already):
(1) Think about analog/modular synths--to connect modules, you would use patchcords. With the E-mu synth engine, the basic connections are built-in, but with "virtual patchcords" you can connect a variety of "virtual modules" (source --> destination and amount).
(2) Take a factory patch, look at the patchcords, tweak them, learn what the various sources and destinations do.
(3) Search the archives for "patchcords." You will find many discussions--from basic to intermediate to advanced.
(4) In the files section, check out the FAQs/Tips and Tricks. A few of them relate to patchcords.
In case you haven'ty figured this out yet, there are two types of cords: (a) ones that affect the synth engine on a layer-by-layer basis (L1, L2, L3, L4) and (b)ones that affect the patch (or preset) on the whole, that is, as a group of up to 4 layers. The first (a) are called PATCHCORDS, the second (b) are called PRESET PATCHCORDS.
You can have up to 24 patchcords per layer. You can have up to 12 preset patchcords per preset. The basic design is as follows:
source --> destination +/amount
For example, if you have only one ROM Instrument in a particular preset--let's say its on L1, and your preset has the following:
L1 PATCHCORDS #01
MidiA -> FiltFreq +100
when you turn knob A, the cutoff frequency of the filter should increase as you turn the knob clockwise.  (There are other factors that go into making a preset, but this should give you the basic idea of how patchcord function.)
Now, change the destination for MidiA to Pitch. Then just explore the different sources and destinations.
Obviously, this is just a basic intro to get you started, if you haven't started yet. If you are beyond these basics already, check out the manual, the archives, the FAQs/Tips & Tricks, and ask away for specifics.
Feel free to share whatever patchcord programming ideas you come up with.
--Steve
