Patchcord's
Patchcord's
2009-11-04 by nedxl7
I've got tis  machine for  years i love it its a beast but i never got to grip's with sum of the patchcord's i kno the basic's for lfo's, destination's, and knob's and midi i just never really got my head around envelope's and crossfade's and changin from one layer to another wit the opening of a filter and stuff like tat its bein doin me skull in for years im tryin make sum nasty dubstepy type music but need them wobbly changing bass's if yee get my drift, any help is greatly appreciated, also sum help for makin sum not so boring arpeggio's! Thanks in advance folks.
Re: [xl7] Patchcord's
2009-11-04 by massimo
I wouldn't worry too much about crossfading layers. I mean you can do a lot with that but it's fiddly and not the first thing you need to draw for.
For dubstep type basses build on a foundation of a layer of sinewave sub, unfiltered probably. Add layers of other waveforms playing an octave or two up and experiment with the different filters. You can modulate the filter cutoffs with LFOs / envelopes etc., using the patchcords of course. You might want to use tempo synced LFOs (although it's a cliche...) and patch one of the MIDI controller knobs to the LFO rate so you can change the speed in realtime. Then you could record that tweaking...
Hope that makes some sense, the manual is quite good on this but there's a lot there and I think they've tended to show off a bit with complicated or esoteric examples. Start simple, and think of patchcords as just that - leads connecting one device to control another.
If you use a computer did you have a look at the Prodatum editor? It makes a lot of this stuff much easier to experiment with.
Massimo
--- On Wed, 4/11/09, nedxl7 <nedxl7@...> wrote:
> From: nedxl7 <nedxl7@...>
> Subject: [xl7] Patchcord's
> To: xl7@yahoogroups.com
> Date: Wednesday, 4 November, 2009, 11:36
> in advance folks.
>     mailto:xl7-fullfeatured@yahoogroups.com
Re: Patchcord's
Yeah i was getting a bit lost a few years ago with the manual and then lost it moving house. I've jus bein using randomize presets and messing about with factory one's since then and picked up a little bit along the way,  thank god i've found tis site its full usefull intake tat should make my little beast a meaner machine thank's for the help
> Massimo
> > in advance folks.
> > Yahoo! Groups Links
Re: [xl7] Re: Patchcord's
2009-11-05 by Bob S.
Manual is available here:
Bob
El Segundo, CA
Sent: Wednesday, November 04, 2009 1:42 PM
Subject: [xl7] Re: Patchcord's
> Massimo
> --- On Wed, 4/11/09, nedxl7 wrote:
> > From: nedxl7
>; > I've got tis machine for
> > in advance folks.
> > Yahoo! Groups Links
