If you have a 1 bar pattern you want extended to 4, you must set
the pattern length to 1 bar *before* executing the extend
command. What happened to you was you extended a 4 bar
pattern out to 4 bars . . . i.e. nothing changed.
Now lets say you do this for track 1 (Kick). Your pattern is now 4
bars of Kick. If you program 1 bar of Snare on track 2 and want to
extend it to 4 bars, you have to reset the pattern length to 1 bar,
then execute the extend command on Track 2. This will now give
you a 2-track, 4-bar pattern of Kick and Snare.
The reason you have to reset the pattern length back to 1 is
because if you don't, the xx-7 thinks your pattern is already 4 bars
(1 full, 3 empty), so there's nothing to extend.
At least, all of this is what I've found works for me. Anyone else
have a better way?
Clay
--- In xl7@yahoogroups.com, Greg Oler <golerage@y...> wrote:
> I did change the length of the pattern before trying
> to have the loop extend over the remaining bars.
> Pretty much the same way the manual shows it. Just
> that the bars I was trying to extend into were empty
> data wise.
> -greg
> --- "jesse_medway <medway808@h...>"
> <medway808@h...> wrote:
> > --- In xl7@yahoogroups.com, "Greg <golerage@y...>"
> > <golerage@y...>
> > wrote:
> > > hello all,
> > > I was wondering if anyone has had problems using
> > the Extend
> > Sequence
> > > Data option under the Pattern Edit menu.
> > Did you change your pattern length to the new
> > length? Otherwise it
> > will still just be playing the 1 bar loop section
> > you started with.
> > To unsubscribe from this group, send an email to:
> > xl7-unsubscribe@yahoogroups.com
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
> http://mailplus.yahoo.com
