Bug with QuickEdit/Mod 1
2002-12-13 by Nick Rothwell
Anyone with the World ROM want to try this?
Select preset 021.0 (plk:Celtic Harp). In quick-edit mode, ramp up
knob M (Mod 1) - this latches and produces vibrato. Select some other
preset, and then come back to Celtic Harp - the vibrato is still
there.
This is utterly bizarre: the vibrato (or Knob M) quick-edit seems to
stay on if I go through a pile of the World ROM presets, gets turned
off for presets in another ROM (with the correct latching behaviour),
but comes back when I switch back to the World ROM. Other quick-edit
knobs (such as those routed to the filter) seem to behave
properly. There's almost certainly something in the voice programming
that's causing this; at present I don't know what it is.
Weirder and weirder: the layer patchcords for this preset don't use
MidiM at all, so I don't see why there's any modulation happening...
(OS 1.32.)
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
Re: [xl7] Bug with QuickEdit/Mod 1
2002-12-14 by Aaron Eppolito
Remember that quick edit is more than just quick edit, it's also a
realtime controller.  Knob M, if you'll notice in the MIDI controller
assign screen, is set to controller #1, which is Mod Wheel.
For the factory XL-7 and MP-7 soundset, new software was written to add
4 more "virtual MIDI controllers, M-P.  Since the World soundset was
created before this new software, it doesn't have assignments for M-P,
but it does respond to Mod Wheel.  The Mod Wheel, however, has no
"initial controller amount" in the preset, so changing presets doesn't
set a value for Knob M, effectively leaving the Mod Wheel value at
whatever it was.
If you'd like, you can set the Knob M initial controller amount of the
offending presets to 0, instead of "off", but you have to then save it
to a user location.
-Aaron
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
2002-12-14 by Nick Rothwell
You mean when the knobs are in "Program" mode? Yup, I noticed that,
but I assumed that knob "Program" mode meant real MIDI out only. (Of
course, now I'm looking at the assignment screen and it clearly says
"int"...)
...but the behavior I described is with the knobs in Quick Edit mode.
> whatever it was.
That makes sense... but I'm looking at the initial controller page for
Celtic Harp now, and M/N/O/P are all set to 000 (not "off").
So, I'm still not clear what's going on here. I'm going to investigate
further.
