yes, I have the same problem, the only choice for me to get that problem is
to use a merge box (Phil rees2Xin, 1Xout), so that you can get direct control
from your computer sequencer and can still use the grid mode for your
external stuff.
Last I get everything back in the XX-7 to get a solid groove.
I can´t tell if it works the right way if U use sonar, because I don´t have
it.
Christoph
Neu: Finanz-Fakten testen jetzt um 35% billiger + ein Geschenk Ihrer Wahl!!
http://bonus.gmx.net/?gid=41442879&prid=688
