Superbeats
Superbeats
2001-10-27 by artedigital@wanadoo.es
Hola
could you tell me if the XL7 has the SUPERBEATS section
like the XL1....
I have the XL1 and am thinking of swapping it for the 7,
but the Superbeats is my favourite feature..
thanks in advance. J
Re: Superbeats
2001-10-27 by M2
No, with the inclusion of the sequencer on the **-7's, SuperBEAT's
was not needed.  Instead they use a pattern mode with the trigger
buttons.  If you look at the Bank presets of the **-7 manuals, you
will notice that the BEATs that are in your XL-1 are all kits on the
7's.
M2
--- In xl7@y..., artedigital@w... wrote:
> Hola
> like the XL1....
Re: [xl7] Re: Superbeats
2001-10-27 by magda
cheers M2. im gonna swap, for sure
j
> De: "M2" <mmcquay@...>
> Responder a: xl7@yahoogroups.com
> Fecha: Sat, 27 Oct 2001 19:33:26 -0000
> Para: xl7@yahoogroups.com
> Asunto: [xl7] Re: Superbeats
> 7's.
> M2
>> Hola
>> like the XL1....
Superbeats
2001-12-17 by jawalsh_sink
Hi all,
This has come up before, but I was unable to find a satisfactory
answer from searching the archives.
Is it possible to access the Superbeats mode on the XL-7?  I
have the new Beat Garden ROM which has a ton of BTS patches
on it, and I'd like to access these.  I know the Superbeats mode
is less of a necessity with the XL-7's built-in sequencer, but Rob
Papen whent to a lot of trouble to come up with all the patterns in
the beats presets, and I'd like to access these.
How do I do it?  Thanks.
John
Re: Superbeats
2001-12-17 by emufreak1
John,
After installing the ROM, did the BEAT's parameters become available
such as key transpose, latch configuration, key velocity and so on?
I know that on my XL-1 the ARPS/BEATS button which is in the same
location as the COMPARE button on your unit gets me access to those
parameters but on my P2K(ORBIT 3), the MULTI button(same location as
the COMPARE button on yours)accesses those parameters.  Since the
units I have demo'ed only had the standard ROM's, I was unable to see
if the screens were the same.
I use a Launch Pad to trigger percussion from the BEATs presets(same
as the 13 trigger pads on the **-7's so without the sequencer, I
basically have **-7's since I have the Pure Phatt ROM installed in
the Xl-1)
http://groups.yahoo.com/group/orbit3/files/Orbit-3%
20Specs/Launchpad.jpg
The way I had to set the BEATs parameters in my setup was to set the
key transpose to +12 because being at 0 with the 13 pad setup on my
Launch Pad would be below where the notes started.  Also make sure
you latch on the parts needed.  1-16, Groups 1-4 and your start, stop
and mute keys as well(as long as you can find the screens first).
Hope this helps.
M2
--- In xl7@y..., "jawalsh_sink" <jawalsh@i...> wrote:
> Hi all,
> John
