Blank Presets and Patterns
2002-11-22 by erik_magrini@Baxter.com
Robert- Even though you emailed me off-list, so did some others with the
same questions, so I'll just send the reply back to the list:
First of all, if you look at the XL-7 Presets, the very last one is a
blank template.  No waveforms have been assigned, and all the patchcords
are empty.  This is the blank Preset I was referring to, all Emu modules
have one in the very last Preset location.  I saved this Preset to User
location 000:0, so that when ever I want to make a new sound, I can just
scroll with the data wheel to the left real quick and have my blank preset
ready to go.  When I want to make a new Preset, I just press Preset Edit,
and then select the first edit menu which is Preset Name.  If you scroll
right once (or press Track mute button 1 again while in Preset edit),
you'll get to the field that lets you assign the different base waveforms
to the Preset.  By using the track up and down buttons to the left of the
display, you can assign different waveforms for each layer.  This is what
I meant when I said I scroll through the waveforms instead of the presets
when I make my own sounds.
Next I copied a blank pattern to all of my unused Pattern locations (using
E-Loader it's pretty quick, still takes time though).  Once you get a
whole bank of blank patterns, it's really quick to do this. So that
whenever I need to work on new pattern, I have nice blank sequencing
canvas already to go, and I don't have to scroll through tons of factory
patterns.
After that, I assigned that blank Preset to all tracks on an empty
pattern, and then I saved the current Multisetup calling it something like
"Default Multi".  You see, if there's nothing recorded in a pattern, it
won't save the preset assignments for the tracks.  A Multisetup will do
this though, it saves all the settings for global, Preset assignments and
midi settings.  In addition, when you first power up the XX-7, the last
used Multisetup will load, which includes all of these settings.  This
way, everytime I power on my XX-7, by default all my tracks have the blank
Preset assigned.
I even take this a step further (I'm anal, I admit it) and do things like
make sure my Effects Sends are all at 1, and that all of my global,
effects, and midi settings are set up the way I want when I save my
"Default Multi".  Not anal enough?  I also saved that Blank Preset to all
of my unused User Preset locations (now that takes time!).  This is nice
for two reasons:
1. I always know when I'm in a User Preset Bank, versus a XL-7 Preset
bank.  Since the User Banks come from the factory with duplicates of the
XL-7 bank presets, it can be slightly confusing when you're working fast
and in a groove.
2. When I save my own Presets, it's easy to see where the next available
free location is.  I just start at 000:0 (err...000:2 nowadays) and scroll
until I see the next Default Preset, then I save my Preset over it.
Could you explain it in more details about your setup of blank presets.
Robert
Re: [xl7] Blank Presets and Patterns
2002-11-22 by Nick Rothwell
> are empty.
Actually, as I recall, the "Default" preset actually has a good many
patchcords already assigned, including the silkscreened control knob
assignments.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
2002-11-25 by erik_magrini@Baxter.com
Sorry, I meant other than those :)  There's no weird assignments, just
ones that coincide with the ones on the front panel.
"Nick Rothwell" <nick@...>
11/22/02 10:42 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        Re: [xl7] Blank Presets and Patterns
> are empty.
assignments.
2002-11-25 by Nick Rothwell
I think there's stuff like mod-wheel-to-LFO and so on. Certainly,
there are sufficiently many that I worry about running out of spare
slots for my own programming...
2002-11-25 by drK
I have to agree.  I normally assign my patch cords from 24 down and almost
every time I end up "farming" some of the default assignments.  In general I
find it better to have a number of specific preset templates for common
sound-types.  For example a bass template or a percussion template.  Many of
the default patch cord assignments make little sense in these situations.
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
