RE:RESTART
RE:RESTART
2002-11-14 by erik_magrini@Baxter.com
From what it sounds like, it will not solve your issue.  Hard to say
without using the feature. This will just let users restart the current
pattern without having to hit Stop x3, then Play.  So yes it will restart
the MPC, but it will also restart your XX-7 at the same time.   May or may
not work for your situation, hard to tell what you're ultimately trying to
do live.
Restart/Fire key combo:  hold play and press stop as often as you
want to restart the current sequence or instantly start playing the
queued sequence
>> do you think this new feature will solve my fucking problem :
restarting
the mpc 2000 (in midi clock slave) without press stop and play... THIS
WOULD BE REALLY GREAT !!!
>>> no ideas ??? nobody ??? ( sean at emu...???)
