So quiet in here...
2002-08-22 by erik_magrini@Baxter.com
Anyone alive out there in XX-7 land? :) Got any tips or tricks to share? rEalm
2002-08-23 by joesapo
Okay, bare with me now, cause i'm pretty much still a beginner, but I just started sequencing all my drum tracks multi channel. My friend who has an MP-7 turned me onto a cool technique using multi channel tracks. It's like having a whole drum kit all in one track, even though I just use the basic single-type presets such as snare-1 and kick-1. I can start track one, which sequences to channels 1a - 6a (snare, kick, hat, etc...) and drop out stuff I don't want via the volume knobs. This works for any tracks I do as long as I sequence them with the same channels. It seems that I get alot more free tracks that way. Instead of having only one main drume sequence using 6 to 8 tracks, I use only 1 track and just use the volume knobs to mix the different stuff in. Most of you guys probably do this anyways, but I thought since it's pretty slow I'd post anyways. BTW... rEalm, I love your stuff. Keep up the good work and keep this forum alive! Sapo --- In xl7@y..., erik_magrini@B... wrote: > Anyone alive out there in XX-7 land? :) Got any tips or tricks to share? > > rEalm
2002-08-23 by erik_magrini@Baxter.com
Sounds like a cool idea, care to go into more detail about what your
channel settings are and what not?
joesapo <joesapo@...>
08/23/02 04:35 AM
Please respond to xl7
cc: Subject: [xl7] Re: So quiet in here... Okay, bare with me now, cause i'm pretty much still a beginner, but I just started sequencing all my drum tracks multi channel. My friend who has an MP-7 turned me onto a cool technique using multi channel tracks. It's like having a whole drum kit all in one track, even though I just use the basic single-type presets such as snare-1 and kick-1. I can start track one, which sequences to channels 1a - 6a (snare, kick, hat, etc...) and drop out stuff I don't want via the volume knobs. This works for any tracks I do as long as I sequence them with the same channels. It seems that I get alot more free tracks that way. Instead of having only one main drume sequence using 6 to 8 tracks, I use only 1 track and just use the volume knobs to mix the different stuff in. Most of you guys probably do this anyways, but I thought since it's pretty slow I'd post anyways. BTW... rEalm, I love your stuff. Keep up the good work and keep this forum alive! Sapo --- In xl7@y..., erik_magrini@B... wrote: > Anyone alive out there in XX-7 land? :) Got any tips or tricks to share? > > rEalm To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2002-08-24 by joesapo
Well it works like this: First off I have my tracks 1 - 8 all setup MultiA. For every pattern I make I use the same (or pretty close) preset setup for those first 8 channels. This usually is laid out something like snare-1 on 1A, kick-1 on 2A, hats-1 on 3A, pretty much just categorize stuff into different sounds. Now when I make a drum track I'll pick a snare from 1A, a kick or two from 2A and so forth. It works out well because I can just use the main volume knobs to mix the different instruments in and out, because the volume knobs are hard coded to control the MIDI channel volume, not the track volume. This way, I can control any drum track i'm playing on any pattern and know that knob 1 is the snare and knob 2 is the kick and so forth. The other obvious benefit is that my drum tracks only take up 1 track instead of 1 per instrument that i want to mix. So this is what i've figured up for pattern switching. If can fit a drum pattern and a couple breaks into 3 tracks, I can fix TWO drum patterns into 6... leaving open that mixing opportunity that we've all been lacking with the current OS limitations. And since ALL my patterns use the same first 8 presets, I can copy and paste that second drum track to whatever pattern i wanna mix to and best of all it only takes 1 - 3 tracks. I have to give props to beat_rebel who roams this forum too. He's the one who sold me his Xl-7 and got me started with this addictive hobby of mine. He's got a Mp-7 now and we've been trying to collaborate on some stuff. Alot of these techniques are stuff that we both came up with. Also, I'm from right around the Chicago area. I remember reading about some of you guys wanting to get together and trade some tips and whatnot. Just lemme know. sapo --- In xl7@y..., erik_magrini@B... wrote: > Sounds like a cool idea, care to go into more detail about what your > channel settings are and what not? > > rEalm > > > > > > joesapo <joesapo@y...> > 08/23/02 04:35 AM > Please respond to xl7 > > > To: xl7@y... > cc: > Subject: [xl7] Re: So quiet in here... > > > Okay, bare with me now, cause i'm pretty much still a beginner, but I > just started sequencing all my drum tracks multi channel. My friend > who has an MP-7 turned me onto a cool technique using multi channel > tracks. It's like having a whole drum kit all in one track, even > though I just use the basic single-type presets such as snare-1 and > kick-1. I can start track one, which sequences to channels 1a - 6a > (snare, kick, hat, etc...) and drop out stuff I don't want via the > volume knobs. This works for any tracks I do as long as I sequence > them with the same channels. It seems that I get alot more free > tracks that way. Instead of having only one main drume sequence > using 6 to 8 tracks, I use only 1 track and just use the volume knobs > to mix the different stuff in. Most of you guys probably do this > anyways, but I thought since it's pretty slow I'd post anyways. > BTW... rEalm, I love your stuff. Keep up the good work and keep this > forum alive! > > Sapo > > --- In xl7@y..., erik_magrini@B... wrote: > > Anyone alive out there in XX-7 land? :) Got any tips or tricks to > share? > > > > rEalm > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@y... > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2002-08-27 by beat_rebel
> sapo
Thanks for the recognition, SAPO.
I might as well fill the forum goers in on my latest scheme. I've set
up custom percussion presets to change instruments by real time
controllers. For example, I program D&B and 90% of the time in D&B the
snare only changes by changing the sample not the sequencing. My
custum presets are ideal for this senario and I've set up all 8 of my
percussion channels in this manner. Not too profound but thought I'd
share.
So here's a question for Sean or Arron:
With all the reliance I'm putting into knobs, I'm looking into buying
an external MIDI controller. I've got my eye on the Doepfer Pocket
Dial. It has endless dials that can operate with out jumps in value.
To avoid confusing you with my personal explanation, here's what the
website says:
Jump-free Parameter Changes
Thanks to the endless rotary encoders used in pocket Dial jump-free
changes of parameters become true provided that some requirements
are met. To realize jump-free changes there are 2 fundamental
solutions:
1. Pocket Dial transmits Increment / Decrement Data
In this case Pocket Dial does not "know" the absolute value of the
parameter but transmits only the information data increment
(abbreviation: inc) or data decrement (abbreviation: dec).
Unfortunately there is no MIDI message available "increase data of
MIDI Controller
XX" or "decrease data of MIDI Controller XX". There is only a general
Data increment (Controller #96 decimal, resp. #60 hexadecimal) and
Data decrement message (Controller #97 decimal, resp. #61 hexadecimal)
available. The third byte of these messages is - as far as we
know - not used so far. In the MIDI spec we found no statement
concerning this byte. Remember: each MIDI control change message
consists of 3 bytes. We want to solve this problem by "hiding" the
controller number, to which the inc/dec is related to, in the third
byte of
these messages. This modified inc/dec messages would enable to
increase or decrease the value of a specific MIDI controller. We hope
that other companies will agree to this proposal and adjust their
software/hardware to this amendment of the MIDI Data
increment/decrement message (controller #96/97).
The "new" MIDI messages are:
Controller Increment: BnH 60H xxH
Controller Decrement: BnH 61H xxH
with n = MIDI channel (0...F) and xx = MIDI Controller No (00...77H,
78H...7FH is reserved for Channel Mode Messages). H means
hexadezimal values.
2. Pocket Dial transmits absolute data
In this case Pocket Dial transmits absolute MIDI Control change data.
After a program change of the device controlled by Pocket Dial
parameter jumps will occur.
Example: The value for filter frequency was 95 for the "old"
program/sound and is 23 for the "new" program/sound. If one operates
control for this parameter there will be a jump to 94 or 96 depending
if the control was operated up or down.
This problem can be solved if the device controlled by Pocket Dial
outputs the new values (i.e. MIDI control changes) for all parameters
after a program/sound change. Pocket Dial receives these values and
uses them as new starting values.
program/sound and is 23 for the "new" program/sound. After the
program/sound change the device controlled by Pocket Dial outputs the
new value 23 for this parameter. Pocket Dial receives this new
value and uses it as the new start value. If one operates the control
for this parameter Pocket Dial will transmit 24 or 22 depending if the
control was operated up or down. This means that there is no parameter
jump as the data transition is 23 -> 24 or 23 -> 22.
But it is essential for this type of control that the device
controlled by Pocket Dial transmits the new MIDI controller data after
a program/sound change. Pocket Dial will receive these data and check
out if one of the controller numbers assigned to the 16 encoders
matches with one of these controller numbers. If this applies the
controller data value will be used as the new starting data for this
controller (of course the MIDI channel has to be the same too). Pocket
Dial and the device controlled by Pocket Dial have to be connected
via MIDI in both directions:
MIDI Out of Pocket Dial -> MIDI In of the device controlled by
Pocket Dial
MIDIOut of the device controlled by Pocket Dial -> MIDI In of
Pocket Dial
I know, thats a lot to read. Will this device be compatible with the
Command Stations?
Thank in advance for your reply,
Beat Rebel2002-08-27 by erik_magrini@Baxter.com
I wish the XX-7's had this functionality to begin with. Guessing what your values and volumes are is a pain. rEalm Thanks to the endless rotary encoders used in pocket Dial jump-free changes of parameters become true provided that some requirements are met. To realize jump-free changes there are 2 fundamental solutions:
2002-08-27 by Aaron
> I've got my eye on the Doepfer Pocket Dial.
This method won't work unless you're trying to control some other gear
that responds to data inc/dec. The sequencer will record it and play
it back, but it won't have any effect on the XL-7's internal synth.
This will work, but to avoid jumps, you'll have to connect one of the
XL-7's MIDI outs to the Doepfer. Your XL-7 MIDI setup will be as
follows:
1 - Rechannelize off (unless you're only trying to control one
channel at a time, in which case you want it set to "always").
2 - Merge MIDI In to Out A (or B; whichever output goes to the
Doepfer).
3 - Knobs transmit MIDI on.
When you change presets, however, the Doepfer won't pick up the
presets' initial controller values, and therefore won't be "in sync"
with the new values and will jump.
What parameters were you planning on controlling?
-Aaron
Do You Yahoo!?
Yahoo! Finance - Get real-time stock quotes
http://finance.yahoo.com2002-08-28 by beat_rebel
--- In xl7@y..., Aaron <synthesis77@y...> wrote: > What parameters were you planning on controlling? > -Aaron For starters, volume on the B channels. They seem to be worthless to me un till I can control their levels in real time. That could be easliy fixed in an OS update ;) After that, I'd set up others controls such as the scheme I mentioned earilier with the drum presets that change samples by RTXfade. I've already started doing that and while I still need to make some more tweeks, it's working out to be pretty cool. I know, I already have 16 programable control knobs, but I'm greedy and if I had that Doepfer, with its 64 virtual knobs, I could easily afford to set up 16 percussion channels and have a bank of 16 knobs to xfade the samples for each. And so on and so on. It sounds like it will work out. If there will only be a jump for preset changes(which I may not do all that often), then I may be able to set the Doepfer up to work around that. Damn I sure babble.... Beat Rebel
