Thanks for the clarification Erik. I haven't taken the XL apart yet
like you have. :)
-- In xl7@y..., "realm619" <erik_magrini@B...> wrote:
> The HEX nuts are only on the headphone and volume knobs, as that
> circuit board attaches itself to the XX-7 case different than the
> rest of them. The pots on the 16 knobs seemed pretty secure
though,
> I was impressed by them when I took them out last time.
> rEalm
> --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote:
> > When I get back in town, I will check again on the XL. I know
that
> > on my regular modules, the potentiometers are secured by the nut.
> > Later,
> > M2
> > --- In xl7@y..., "David Jones" <spec@s...> wrote:
> > > hMMM
> > > my unit doesn't have the hex bolt. it just has the threads.
> There
> > is nothing holding the whole thing in there.
> > > On the MASTER VOLUME knob, however, there is a bolt! Maybe
they
> > just started doing this reciently? ANyone else have missing
bolts?
> > > ----- Original Message -----
> > > From: emufreak1
> > > To: xl7@y...
> > > Sent: Wednesday, July 24, 2002 9:15 PM
> > > Subject: [xl7] Re: Loose knobs?
> > > David,
> > > If you pull gently on the knob outward, it will come off.
> Behind
> > it
> > > is the moon shaped nipple with threads on it. There is a hex
> > head
> > > screw that snugs it to the faceplate which you can tighten to
> > > eliminate the wobble.
> > > Later,
> > > M2
> > > > I'm a little worried about my knobs on my MP-7 - I'm kindof
a
> > > hypocondriac whien it comes to gear, but i've had my problems
> > with
> > > things before. Of the 16 knobs on the left, knob #1 feels a
> > little
> > > bit wobbly. I'm affraid with too much tweaking, it might
come
> > loose
> > > a little bit and detatch itself from the mainboard. There's
> > nothing
> > > holding it down now, but does anyone know if adding some
bolts
> to
> > > keep the secure might be a good idea??
> > > Yahoo! Groups Sponsor
> > > ADVERTISEMENT
> > > To unsubscribe from this group, send an email to:
> > > xl7-unsubscribe@y...
> > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service.
