Re: [xl7] Werd to your whole setup -> MIDI SYSEX THRU DAMMIT
2002-07-23 by David Jones
This is not the reply I was looking for :( I will contact EMU with my problem...
Sent: Monday, July 22, 2002 11:43 PM
Subject: Re: [xl7] Werd to your whole setup
Based on what you say, I think you are right. There is no mention of this or anything like it in the manual or addenda that I can see. Have you sent an e-mail to E-mu directly?
Til then it looks like you will have to patch/repatch or use a different external merger or a separate usb->midi box like a small midiman or something.
Sent: Monday, July 22, 2002 10:27 PM
Subject: [xl7] Werd to your whole setup
Ok, I asked it before, and maybe i didn't explain my situation well enough.
I'm running an A4000 (yamaha sampler) out of my MP-7. I also have my computer plugged into the Mp-7. I have MIDI MERGE ON on the MP-7. When I use a sequencer, the Note data goes right to my A4000 no problem. But when I try to get SYSEX data to it (from BZONE), it doesn't work! It works fine when I run right out of my computer into the A4k. So I figure there must be some filtering going on... ANYONE?"
RE: [xl7] Werd to your whole setup -> MIDI SYSEX THRU DAMMIT
2002-07-23 by Andre Lewis
There's a huge chance you need to plug the A5000 into the OutB and set midi in to midi out (Midi menu, Midi Merge OutB)
Sent: Monday, July 22, 2002 11:08 PM
Subject: Re: [xl7] Werd to your whole setup -> MIDI SYSEX THRU DAMMIT
I'm running an A4000 (yamaha sampler) out of my MP-7. ; I also have my computer plugged into the Mp-7. I have MIDI MERGE ON on the MP-7. When I use a sequencer, the Note data goes right to my A4000 no problem. But when I try to get SYSEX data to it (from BZONE), it doesn't work! It works fine when I run right out of my computer into the A4k. So I figure there must be some filtering going on... ANYONE?"
tried that
Sent: Tuesday, July 23, 2002 2:46 AM
Subject: RE: [xl7] Werd to your whole setup -> MIDI SYSEX THRU DAMMIT
You definately tried it using port B? I know they strip all sorts of things out port A, I've not tried the sysex on port B...
Sent: Tuesday, July 23, 2002 7:15 AM
tried that
Re: Werd to your whole setup -> MIDI SYSEX THRU DAMMIT
2002-07-23 by drj0
I Definatly tried it.  I will try it again though when i get home
from work :)
of things
>   -----Original Message-----
>   From: David Jones [mailto:spec@s...]
>   To: xl7@y...
DAMMIT
>   tried that
>     ----- Original Message -----
>     From: Andre Lewis
>     To: xl7@y...
DAMMIT
and set
>       To: xl7@y...
THRU DAMMIT
EMU with my
> problem...
>         From: Ravi Ivan Sharma
>         To: xl7@y...
mention of
Have you
use a
midiman
> or something.
>           From: David Jones
>           To: xl7@y...
situation
> well enough.
also have
7.  When
problem.  But
It works
there
>           xl7-unsubscribe@y...
of
> Service.
Service.
Service.
Service.
>         Yahoo! Groups Sponsor
>               ADVERTISEMENT
Service.
