Pulswidemodulation
Pulswidemodulation
2002-07-08 by pocketd@gmx.de
how do you make a fat Pulsemodulation with the XL-7?
Is it just by using the Chorus? Is it better to connect LFO wirh chorus
amount, I can\ufffdt hear any effect doing that, it\ufffds the same as on my EMU 5000
Ultra, I dont know why,
Thanx,
Christoph
P.S. See my videos on Flowmotion 1.0 DVD.
paybox macht Ihr Handy zur Geldb\ufffdrse!
http://bonus.gmx.net/?gid=41442879&prid=540
Re: [xl7] Pulswidemodulation
2002-07-08 by Nick Rothwell
The Xl-7 is sample-based, so I don't see any way of doing authentic
PWM. You'd need to fudge it: chorusing/FX maybe, or something in the
filtering, or perhaps just layer-crossfading between waves with
different duty cycles.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
RE: [xl7] Pulswidemodulation
2002-07-08 by Byron
I think your best bet would be to detune all four layers of a sound, I think
for the best bet at reproducing a true pulse width, you would use for layers
of pulse waves (not sure if the xl's roms has different widths of sampled
pulse waves, havent done TOO much editing on it yet)...in any case, yes,
take 4 layers of pulse waves, or your preferred sound and detune (the 'fine'
tune) them all slighty in respective order (ie, each one a bit more than the
nest). if it's too heavy of a slush, than lower the volumes of some of the
layers individually. The less the detune, the slower, yet more defined the
effect. Yes, this is just essentially a home-made chorus, but i personally
think it yields better results for fatness. It also is, well, synth
programming 101, but everyone starts somewhere. If you try useing different
waveshapes together, like a saw, square, triangle, and ____ (fill in the
blank), or even just two waves, it's easier to create the thinning tear that
makes the tru PW so beautiful. Doing all of this and then upping the octave
by 12' and/or 24' on one or two of the layers, and fine tuning them at a
minus degree and then fine tuneing the lower pitched layers at positive
degrees can really create some rich and swarthy sounds!
Of course, you can still just chorus them...but a chorus, well, is just so
noticeably a chorus.
Byron
Chaos exists as raw material from which to create order.
-Reverend Mother Superior Darwi Odrade
Sent: Monday, July 08, 2002 8:28 AM
Subject: [xl7] Pulswidemodulation
Thanx,
Christoph
