Final Error, help....
2002-06-20 by pocketd@gmx.de
I really don\ufffdt understand, why I have all the same presets on every pattern
on my XL-7, they just all changed.
 First it happend I choosed restore multisetup, all the different presets of
the patterns were back again, but then I saved it again, now it do not
restore the presets.
could someone please help me?
I don\ufffdt know why this happens?
I don\ufffdt work with program changes so far, but what happend is a final error.
Sometimes I could throw it all away, because there\ufffds always something not
working.
Thanx,
Christoph
Genion: Mobile Kommunikation ohne Kompromisse!
http://bonus.gmx.net/?gid=41442879&prid=523
Re: [xl7] Final Error, help....
2002-06-21 by erik_magrini@Baxter.com
If you change Patterns, new Presets will loaded based on what is saved with the Pattern. When you reload a Multisetup, new PAtterns will again be loaded, based on what Presets you had aassigned when you saved the Multi. Switching to a new Pattern at this point will, you guessed it, load up the Presets assigned to the Pattern.
pocketd@...
06/20/02 02:38 PM
Please respond to xl7
; cc:
Subject: [xl7] Final Error, help....
I really don´t understand, why I have all the same presets on every pattern
I don´t know why this happens?
I don´t work with program changes so far, but what happend is a final error.
Sometimes I could throw it all away, because there´s always something not
working.
Thanx,
Christoph
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/3PCXaC/PfREAA/Ey.GAA/pWZylB/TM
Re:Final Error, help....
2002-06-21 by pocketd@gmx.de
-"If you change Patterns, new Presets will loaded based on what is saved-
with the Pattern."
Yes, right, that\ufffds the way it worked as it came from the factory.
"When you reload a Multisetup, new PAtterns will again be loaded, based on
what Presets you had aassigned when you saved the Multi."
Am I right, that a multisetup saves the settings of the presets in the
current choosen Pattern, or saves a multisetup all patterns of the whole XL-7?
 " Switching to a new Pattern at this point will, you guessed it, load up
the Presets assigned to the Pattern."
But what\ufffds that good for to have all the same presets on every pattern?
I just can tell what I see,  if I turn on that box I already have all the
same presets on every pattern, that wasn\ufffdt at the beginning.
So I choose a multisetup (factory setupup) and all the Presets of all
Patterns are back. But why?
It\ufffds really confusing, or am I confused?
thanx,
Christoph
                        pocketd@...
                        06/20/02 02:38 PM
                                To:     xl7@yahoogroups.com
                                cc:
presets on every
                        pattern
                        of
happend is a final
                        error.
                        working.
                        Thanx,
                        Christoph
Haftpflicht sagenhaft g\ufffdnstig! Wo? Bei InsuranceCity!
http://bonus.gmx.net/?gid=41442879&prid=501
Re: [xl7] Re:Final Error, help....
2002-06-24 by erik_magrini@Baxter.com
Am I right, that a multisetup saves the settings of the presets in the current choosen Pattern, or saves a multisetup all patterns of the whole XL-7?
>>>A multisetup saves all (well, most) parameters in the box as it is WHEN YOU SAVE THE MULTISETUP. When you power on the XL-7, the last used multisetup loads automatically. <<<
But what´s that good for to have all the same presets on every pattern?
>>>Depends on how you work. For me personally, I like to start witha blank template every time I power on the XL-7, so I created a Multisetup with all tracks assigned the "Default ver. 1.00" Preset, all FX sends set to 0, all Pans at center, and all volumes at 100, not to mention all of the appropriate MIDI settings too. By leaving the very first pattern empty (User Bank 0, Pattern 000), that multisetup will load each time I turn on the XL-7, giving me a blank canvas so to speak. <<<
same presets on every pattern, that wasn´t at the beginning.
>>>Because both the Multisetup, and your patterns will save the Preset assignments when you save them. So, if you call up a Pattern, it's Preset assignments will be loaded, if you then restore a Multisetup, then the presets that were assigned to each track when you saved the multi are loaded. Pressing Play will cause the Presets in the pattern to reload however, as that has priority over the multisetup. <<<
It´s really confusing, or am I confused?
>>> a bit of both probably :) <<<
