I moved to Cubase SX But suddenly my XL7 can not control VSTi
2002-06-12 by nbaryosef100
I moved to Cubase SX But suddenly my XL7 couldn't control VSTi.
I am asking that question here because I know guys using it with
their XL.
1- I was able to control VSTi's using Cubase VST 32.
2- In the Transporter in Cubase it shows massages are coming in.
3- No sound from the VSTi's
If anyone had the same problem and solved it let me know, or anyone
that use SX and knows what I need to do.
Thank you
NiR
Re: [xl7] I moved to Cubase SX But suddenly my XL7 can not control VSTi
2002-06-12 by erik_magrini@Baxter.com
A couple things to check:
1. Make sure that you're not accidentally filtering out CC's.  It's in the
MIDI Preferrences.
2. Of course make sure that the VSTi is assigned to a MIDI track set to
the appropriate channel.
3. Make sure you've got MIDI Thru activated in SX too, other wise the
program will see the incoming data, but our VSTi's won't.  I miss this one
all the time and spend hours sctratching my head and testing my cables :)
4. You may have noticed that the MIDI port assignments are all messed up
in SX.  Each 'real' port is duplicated in the list (with no way to tell
which is the right one), and there's an "emulated" version available too.
Make sure you try out different port settings, like I said, the ports are
duplicated, and only one of them will work, but there's no way to know
which until you try.  Once you find it, best bet is to rename it so in the
future you know right away.  BTW this is known bug to be fixed in the next
SX update.
I just got the official version of SX installed yesterday (had to reformat
and reinstall ALL my programs to get it to work, grrr!) so I'll play
around with this tonight too and see if I get the same results.
their XL.
Thank you
NiR
Re: I moved to Cubase SX But suddenly my XL7 can not control VSTi
First thing thank you, second i will try it later i am still at work
:(( plus, removed the old cubase and installed the new one, there was
no need to reinstall programs every thing worked just fine.
NiR
in the
> MIDI Preferrences.
set to
this one
cables :)
messed up
tell
available too.
ports are
know
in the
the next
> SX update.
reformat
play
> rEalm
> their XL.
> Thank you
> NiR
> xl7-unsubscribe@y...
