Well, yes and no. True, in the middle of a pattern you can't change the
mute status of your tracks, but there's a sorta workaround. In song mode,
you can specify that any step can be any length (as in number of
measures). So even if you have an 8 measure pattern, you can tell that
step in the song to only be 4 or 2 measures long if you want. So you can
break your 8 measure pattern up into eight 1 measure Steps if you wanted,
and apply different Track mutes that way. The downside? If you tell a
Step to be shorter than the length of the pattern (as in the above example
with eight 1 measure steps), the pattern will always restart at each step.
So in effect, you'd get the first measure repeating 8 times. No
workaround for that except to use an external sequencer...
Right now I am diving into SONG mode. I've only done a little bit, but
from what I read in the manual (tfm), It appears that I can't turn on and
off tracks in the middle of a pattern in my song... Or am I completely
wrong?
