Prog change msgs to another groovebox/pattern sequencer
2002-04-29 by peebs uk
I want to use the XL7 to control and change patterns on 3 other groove boxes
(Korg Electribes). The problem is that the prog change is usually received
just after the pattern starts, causing the new pattern not to kick in until
the end of the current one.
Does anyone out there have any idea how I'd get these to be received just
before the pattern starts? The alternative is to put the program changes at
the end of the preceding pattern but that mean I won't be able to change
them on the fly.
Cheers,
Steve
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
Re: Prog change msgs to another groovebox/pattern sequencer
2002-04-29 by mikexl7
Well there is the ability to place cc info on the tick 001.01.000 in
the list editer but mine has stoped working for some unknown
reason.  Asuming that yours is not doing what mine is just go into
the list editer and press the repeat button and then select the cc
info to send a program change.
P.s. the track has to be set to external to access the tick
001.01.000.
I think this will work.
Mike G
groove boxes
received
in until
received just
changes at
change
> them on the fly.
> Cheers,
> Steve
RE: [xl7] Prog change msgs to another groovebox/pattern sequencer
2002-04-29 by Andre Lewis
Create a short sequence that's nothing but the program change info in an ext
seq.  Make sure it's at the same tempo, then switch to it then your actual track
in song mode?
Sent: Monday, April 29, 2002 6:26 AM
Subject: [xl7] Prog change msgs to another groovebox/pattern sequencer
them on the fly.
Cheers,
Steve
Re: [xl7] Re: Prog change msgs to another groovebox/pattern sequencer
Thanks for the advice Mike, I think that would do the trick if... I wasn't
having the same problem as you! Just tried to add a cc event on an external
only track and the lowest tick I can use is 001.01.001 (running o/s 1.31)
As you're experiencing the same problem should I repost this with the
subject 'Can't enter event at tick 001.01.000' or has this problem already
been discussed with no solution?
Steve
>From: "mikexl7" <mikexl7@...>
>Reply-To: xl7@yahoogroups.com
>Subject: [xl7] Re: Prog change msgs to another groovebox/pattern sequencer
>Date: Mon, 29 Apr 2002 14:04:28 -0000
>001.01.000.
>Mike G
>groove boxes
>received
>in until
>received just
>changes at
>change
> > them on the fly.
> > Cheers,
> > Steve
Just a thought, the v1.31 manual says that you can view this tick for
removing xl7 presequence setup data from external tracks (but doesn't
mention adding anything in there yourself). Maybe there's a way of getting
some xl7 data in there which can then be changed to an external cc as the
tick only seems visible when there's something already there?
Does that make any sense, and if so can you think how the xl7 data can be
put in there?
PS. Tried controlling the korgs for the first time since the change in o/s
and the prog change events at 001.01.001 are still too late.
>From: "peebs uk" <peebs_uk@...>
>Subject: Re: [xl7] Re: Prog change msgs to another groovebox/pattern
>sequencer
>Date: Mon, 29 Apr 2002 14:46:15 +0000
>Thanks,
>Steve
>sequencer
> >001.01.000.
> >Mike G
> >groove boxes
> >received
> >in until
> >received just
> >changes at
> >change
> > > them on the fly.
> > > Cheers,
> > > Steve
