Re: [xl7] FAQ enclosed (new corrections soon)
2002-04-08 by erik_magrini@Baxter.com
Uh, thanx. Scott got your comments too, I'll fix them all later today. rEalm And for each of these cases: >-Is there any way to initialize a Pattern to it's default settings? >-Is there anyway to initialize a Preset to it's default settings? > and that your Command Station is >connected with both it's MIDI in >This usually only happens if you are >holding a note when the Patterns loops back to it's beginning, >it may be best to use that hi hat Preset on it's own Track. >because the value is >already at it's maximum. you should have "its" rather than "it's." I-T-apostrophe-S means "It is." (And you use it correctly in other spots in the FAQ, such as "While it's not possible to modify ...") --- * Radio Free Entropy: http://just-john.com/cn/rfe.shtml * To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
