[xl7] new os doesnt work for me
2002-04-05 by Lynn Bruington
i tried to load the new os and eloader tells me that the file does not pass validation tests and cannot be used. whats up with that??
Re: new os doesnt work for me
2002-04-05 by nifflas
It also happends to me. btw there's probably a bug in E-Loader 1.1 as
well, since I had the problem with installing the new OS, I decided
to load E-Loader 1.1 and try again. But when I start it, it just says
that "The native MIDI code library could not be found" and won't run.
Re: [xl7] Re: new os doesnt work for me
2002-04-05 by Jonathan El-Bizri
Has anyone got it loaded yet?
Jonathan
Sent: Thursday, April 04, 2002 5:04 PM
Subject: [xl7] Re: new os doesnt work for me
i've even tried to use the old version of eloader to do this and it didnt work......i guess we're just gonna have to wait till tomorrow
Sent: Thursday, April 04, 2002 7:11 PM
Subject: Re: [xl7] Re: new os doesnt work for me
Jonathan
Re: [xl7] new os doesnt work for me
2002-04-05 by Aaron Eppolito
Sorry, ZipIt for some reason corrupted the file.
The corrected command131.zip is up on the web...simply redownload.
-Aaron
2002-04-05 by Scott Ruda
I just downloaded both the Mac and PC versions and installed them and they
work fine for me.
What OS are you using? I'm guessing that possibly you are on a Mac and don't
have OMS installed? But you implied that E-Loader 1.0 was working fine for
you?
I'll continue to pursue it on my end till someone tells me otherwise...
Scott
it works now....thanx alot
Sent: Thursday, April 04, 2002 7:26 PM
work fine for me.
you?
Scott
Using a PC, Windows 95. At the other hand, I'm not going to use the
USB port so I guess that's not the problems.
I tried to install it on 2 different computers and got the same error
message.
Very weird.
decided
says
run.
and they
> work fine for me.
and don't
fine for
> you?
otherwise...
> Scott
The read me says there is no windows 95 support.
See you all later :>
bIz
Sent: Thursday, April 04, 2002 5:43 PM
message.
Very weird.
decided
>; > to load E-Loader 1.1 and try again. But when I start it, it just
says
run.
and they
> work fine for me.
and don't
fine for
> you?
otherwise...
> Scott
> bIz
> From: nifflas <mailto:nifflas@...>
> message.
Actually, E-Loader 1.1 *should* work fine on Win95 with MIDI, it just won't
do USB. The error message you are reporting should not happen under any
conditions. I do think it is related to the fact that Win95 doesn't support
USB, but we had developed the code with that in mind and tested that case
and it worked fine for us. Something may have gone wrong in the final build
or installer. Let me look into it.
Scott
2002-04-05 by fred z
i can't load new os whats the deal please
help...thanks
>     From: Jonathan El-Bizri <mailto:sserendipity@...>
>     To: xl7@yahoogroups.com <mailto:xl7@yahoogroups.com>
>     Jonathan
>         --- In xl7@y <mailto:xl7@y>..., "Lynn Bruington" <nufleisch@k
>         does
>         1.1 as
>         says
>         run.
>         Service <http://docs.yahoo.com/info/terms/>.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/M=215002.1954253.3462811.1261774/D=egroupweb/S=1707709865:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1017969296%3eM=215002.1954253.3462811.1261774/D=egroupweb/S=1707709865:HM/A=1000239/R=1>
oh,so i should go back to the site and down
load the new one?  ok i'll try that, thanks Scott
scottr@... wrote:
>  > help...thanks
> What happens? The problems that others had were resolved (a bad posting
> of the OS image was replaced within an hour of the original post).
> Scott
> ADVERTISEMENT
> <http://rd.yahoo.com/M=178320.1964497.3448863.1261774/D=egroupweb/S=1707709865:HM/A=879171/R=0/*http://www.fastweb.com/ib/yahoo-57f>
> help...thanks
Scott
what's the os image and where do i get from.
>  > help...thanks
> Scott
> ADVERTISEMENT
>>> help...thanks
I'm a bit confused. You said you can't load the new OS, then say you
don't know what an OS image is??? What did you try to do to load the new
OS?
The new OS and the new E-Loader (the application used to update the OS)
can be found here:
http://www.emu.com/products/xl7/downloads.html
Scott
Again, you only need to re-download the OS if you grabbed it within the
first few minutes of it being posted, which was at about 4:15 this
afternoon (California time). If you just got it in the last hour you
don't need to re-download it. What kind of error did you get? If the
error is something like 'the file doesn't pass validation tests' then
you have the bad one. If you get some other error, then you have a
different unknown problem.
Scott
Ok, got the new os loaded,i had forgot to do
the prep thing first thanks.....i notice with
the channelization featrue i can excess 1-16a
tracks that is, but how do get more trks
like an additional 16, in other words there
32ch but how do i sequence them if i only
have 16 tracks.
> Scott
> ADVERTISEMENT
> <http://rd.yahoo.com/M=215002.1954253.3462811.1261774/D=egroupweb/S=1707709865:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1017988205%3eM=215002.1954253.3462811.1261774/D=egroupweb/S=1707709865:HM/A=1000239/R=1>
