Extension interval bug - os 1.18
2002-03-31 by nifflas
Try this. Make a new preset, use the arpeggiator, but not a pattern
arp. Set the extension count to something more than 1, then extension
interval to 12. Save the preset, select another preset and then
select the preset you just saved (now it's gone from the edit
buffer). Then play some notes on the keyboard. Now the arpeggiator
acts like the Extension interval is set to 1 instead of 12. Go into
preset edit mode again, and check the extension interval. It still
says 12, but it acts like it's 1. Change it to 11 and back to 12. Now
it works correctly. Not good.
