As my setup evolves: Currently the sub-outs are used, hard-panned, for 4 mono outs. The digital output goes into a dual channel / multiband compressor. I can route the whole mix through the multiband, or apply individual compression to 2 mono channels (Snare, percussion, etc.). Even better, this setup allows parallel or 'New York' style compression. I can mirror all or some of the drums on a seperate track kit, then bus that track through the compressor at extreme settings, and mix back with the original signal. Big drums! Easily done in software too.
One thing about the FX sends - as only the dry signal leaves the sub outs, it' still possible to use the 4 FX sends, but the wet signal goes to the main outputs. So it's possible to apply a variable amount of FX to each send, then parallel compressing the wet output with interesting results. I find the CS FX pretty weak overall, but try this with a teeny-tiny amount of reverb before the compressor, or throw in a distorted flange or delay. There's gold to be had in tweaking those busses.
BTW - my SKB case arrived and it's perfect for the Command Station plus 8 rack spaces. I gave-up looking and made my own racks ears for <8euro. Pics:
here
--- In xl7@yahoogroups.com, James Ulibarri wrote:
> yes, chords and tones from the ASR-X and percussive sounds from the SP1200.
> and then bass lines from ASR-X #2 in a few days with the PX-7 spitting midi
> to both machines. one of the machines will be getting the 8 out upgrade, but
> not both.
> i want to get one of them painted like this one... sick
> http://ghostinmpc.com/?p=219
> On Mon, Feb 28, 2011 at 12:27 PM, James Ulibarri jamesulibarri@...wrote:
> > they are not $600 on Ebay, Matt. Tons of sold on Ebay for less than $300
> > in the last few weeks. Don't listen to the hype about the red one being
> > better. In fact the red one has more bugs than the classic black one. And
> > regarding the SP1200 re-issue...
> > It will never happen. Creative won't sink any money into Emu development
> > like that. They want to do cheaply made stuff like midi controllers and
> > interfaces with two lousy outs, etc.
> > Besides it would be a lot more than $600 if they were to do one. A lot
> > more. Furthermore it would be technically be a re-issue mkII or mkIII
> > because they have already had a reissue in the 90's after it was
> > discontinued.
> > On Mon, Feb 28, 2011 at 8:59 AM, Matt somatt@... wrote:
> >> Like I said If I can find one they are 600 on ebay buy it now which seems
> >> like a joke. For that price I can wait for them to re-issue the sp-1200
> >> again. Or get an emax and a eps. But then I'm gonna be bloated again.
> >> In the mean time I am riding this CS dragon till I tame her. I'm LOVING
> >> the sub outs. I'm figuring out cc79 (thanks atom!) and trying to figure out
> >> the fx with are STARTING to sound cool as I figure out the sends.
> >> Your using asr-x for all your sounds now?
> >> On Feb 28, 2011 12:33 AM, "James Ulibarri" jamesulibarri@...
> >> wrote:
> >> "I guess I took gas-x cuz no more GAS."
> >> What you need to take is gas-asr-X and get one of these bad boys something
> >> fierce.
> >> On Sun, Feb 27, 2011 at 9:54 PM, Matt somatt@... wrote:
> >> > thank you!! This is aweso...
