my XL-7 does't start anymore !!!
2010-11-10 by XL-7 Group
Hi Guys,
I have no ideea what could it happend, yesterday my xl was working perfect and now is not starting. Is looking like no electricity is getting in. I check different cables and different electricity sources. Have any ideea?
Re: my XL-7 does't start anymore !!!
2010-11-10 by nenad.lonic
--- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@...> wrote:
> Hi Guys,
> Thanks
Open her up, and check that the connector that comes from the on/off button hasn't come out. While it's open put a multimeter across the on/off switch pins and check that its still working
2010-11-13 by Dacian
ohh man, i think is kind of bad.
I just had a friend with a multimeter, and. The fuse is ok. And on the pins coming from the electric source there is 9 volt on (yellow and brown). We have no idee what should it be. Any advise would be very apreciate. /Thanks, guys
--- In xl7@yahoogroups.com, "nenad.lonic" <nenad.lonic@...> wrote:
> --- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@> wrote:
> > Hi Guys,
> > Thanks
Re: [xl7] Re: my XL-7 does't start anymore !!!
2010-11-13 by Jack Pratt
Fuse?
My XL7 doesn't have a fuse. Unless there's one inside the power supply enclosure
(which I would doubt due to its inaccessibility - there might be a polyswitch
["ptc device" or "resettable (thermal) fuse"]). And there's no brown and/or
yellow wires.
It has a 10-way single-in-line (molex type) connector on the main board [with 10
wires coming from the power supply] and next to the connector (on the main
board) there's a list of the voltage on each pin [+15, -15, GND, GND, +5V, +5V,
+3.3, +3.3 and two others]. Although there are individual wires from the power
supply to this connector there are no brown and/or yellow wires as it turns out
[purple, green, black red, orange...]
It may be that you have a different variant XL7 than I have but I would be
surprised if there were multiple revisions of the XL7 main board so radically
different.
In any case I would surmise that the most-likely problem is that your power
supply gave up and possibly the main board could have been damaged in the death
of the power supply. There is no value in turning the power on and risking
further damage to the main board. If you disconnect the power supply (from the
main board) you could check the no-load voltage on the power supply connector
and check what happens under load [if you put a 1K resistor across any two wires
the voltage should change not at all if the power supply is working properly,
even a 10ohm resistor should have little effect (except perhaps on the +15 and
-15 sources which would be unlikely to sustain 1.5A) if applied for a _very_
short time]
Solution:
If you can verify that the power supply is defunct then get a new one [although
if you were sufficiently skilled in electronics you might be able to fix it],
but the main board may also have suffered damage. The 'new' power supply will
probably have the same source as the 'new' main board - ebay.
Sent: Sun, November 14, 2010 12:05:23 AM
Subject: [xl7] Re: my XL-7 does't start anymore !!!
> > Hi Guys,
> > Thanks
2010-11-13 by Matt
New power supplies and new main boards are avail at epr.
On Nov 13, 2010 1:33 PM, "Jack Pratt" <woodsworth1@...> wrote:
Fuse?
My XL7 doesn't have a fuse. Unless there's one inside the power supply enclosure (which I would doubt due to its inaccessibility - there might be a polyswitch ["ptc device" or "resettable (thermal) fuse"]). And there's no brown and/or yellow wires.
It has a 10-way single-in-line (molex type) connector on the main board [with 10 wires coming from the power supply] and next to the connector (on the main board) there's a list of the voltage on each pin [+15, -15, GND, GND, +5V, +5V, +3.3, +3.3 and two others]. Although there are individual wires from the power supply to this connector there are no brown and/or yellow wires as it turns out [purple, green, black red, orange...]
It may be that you have a different variant XL7 than I have but I would be surprised if there were multiple revisions of the XL7 main board so radically different.
In any case I would surmise that the most-likely problem is that your power supply gave up and possibly the main board could have been damaged in the death of the power supply. There is no value in turning the power on and risking further damage to the main board. If you disconnect the power supply (from the main board) you could check the no-load voltage on the power supply connector and check what happens under load [if you put a 1K resistor across any two wires the voltage should change not at all if the power supply is working properly, even a 10ohm resistor should have little effect (except perhaps on the +15 and -15 sources which would be unlikely to sustain 1.5A) if applied for a _very_ short time]
Solution:
If you can verify that the power supply is defunct then get a new one [although if you were sufficiently skilled in electronics you might be able to fix it], but the main board may also have suffered damage. The 'new9; power supply will probably have the same source as the 'new' main board - ebay.
I just had a friend with a multimeter, and. The fuse is ok. An...
$152 does not seem like such a bargain when there is a reasonable chance that
the main board is also damaged and that it would likely need replacement as
well. Its all a question of risk that you're willing to sustain.
Sent: Sun, November 14, 2010 7:36:49 AM
Subject: Re: [xl7] Re: my XL-7 does't start anymore !!!
>Fuse?
>yellow wires.
>different.
>short time]
>Solution:
RE: [xl7] Re: my XL-7 does't start anymore !!!
2010-11-13 by craig ward
Sounds like the same problem I had :( I tested and there was no output on the power supply at all so I went ahead and ordered one from eprelectronics. Its still in the mail so when it gets here i'll let you know if it fixes the problem or if the motherboard is toast. Usually you can look at a PC board and see a visible sign of a burn out so have a close look at that, and also smell the power supply, if its cooked it will have a burn smell about it.
Date: Sat, 13 Nov 2010 14:05:23 +0000
--- In xl7@yahoogroups.com, "nenad.lonic" wrote:
> --- In xl7@yahoogroups.com, XL-7 Group wrote:
> > Hi Guys,
> > Thanks
Re: RE: [xl7] Re: my XL-7 does't start anymore !!!
2010-11-13 by Matt
If u can't fix it I bet the guys at epr can.
2010-11-14 by Dacian Victor
THANKS for your answers.
You are right, there is no brown wire.
What did i want to say is this, on the pins coming from the electric source there is 9 volt on first(yellow) and last but one(purple).
Ok, i attach a image from the connector. On the rest of the pins there is nothing.
 /see you later
Date: Saturday, November 13, 2010, 1:36 PM
      Fuse?
Solution:
 able to fix it], but the main board may also have suffered damage. The 'new' power supply will probably have the same source as the 'new' main board - ebay.
2010-11-14 by duncan
I had one of these switched-mode power supplies let go in a proteus rack module; it did no harm to the main board, & I suspect the manufacturer of such things would be pretty unpopular if their products ever did any harm to their customers' boards. :-)
they're standard units, but always check the order of the output connections before fitting anything that wasn't meant to go in an emu. you need, as I recall, a good supply of +5 & +12 & also -12.
duncan.
