Any solution
Any solution
2010-10-06 by Stephane
Hi I would like to know if there is any solution now or if the bug had been fixed about the souncrash when u change of pattern and use a different setup on the XL 7.
I bought mine in 2003 and I had never found any solution when I play live except of sampling the two patterns to chain them in a set'
I am French so if you could be nice and write for a beginner in English that would be cute !
www.myspace.com/inuitunit
Re: [xl7] Any solution
2010-11-24 by Aaron Eppolito
Are you using 2.0?  If not, download it.  It's chock full of goodness.
-Aaron
ps. if you are already using 2.0, perhaps explain the bug a little more?
2010-11-24 by PLASTICEFX@aol.com
any mac compatability yet for this upgrade?  been waiting years for that s.o.b.!  '-)
plastic
To: xl7 <xl7@yahoogroups.com>
Sent: Tue, Nov 23, 2010 9:49 pm
Subject: Re: [xl7] Any solution
-Aaron
2010-11-24 by Stephane
I have the version 2.0 os and one different sound cards in slots : proteus 1000
The bug is:
 when a pattern is playing with the XL7 sound card and when I pass to another pattern using the proteus 1000 sound card it makes crashs the first time the pattern is looping and after it turns normally ( it makes the same in the other way when a pattern is changing  from proteus sound card to xl7 )
Althought I can change the setup of the pattern currently displaying with a proteus setup for not having a sound crash but that's not the effect researched)
plastic
-Aaron
