real-time, continuously variable, PWM LFOs
2010-04-26 by Atom Smasher
how to get real-time, continuously variable, PWM LFOs. or; another neat
thing i thought of while trying to figure out something else, realized
that this is cool in its own way, and just now had a chance to test out.
enjoy...
LFO1:
 wave: triangle or sawtooth
cords:
 1: LFO1+-  ->  switch  +100
 2: switch  ->  *target*
 3: DC      ->  switch  +0 (controlled by #4)
 4: MIDI-A  ->  CO3     +49-50
this produces a square wave with the duty cycle controlled by knob A (cord
#4). if cord #4 is set to +50, the pulse can be set flat. if set to 49, it
can be set to just a tiny pulse (probably 2%?).
of course, if you want something more rounded than a square wave just
change cord #2 and add one more cord:
cords:
 2: switch  ->  Lag0    +??
 5: Lag0    ->  *target*
in this case, the range of cord #2 determines how much of the edges are
rounded off the square.
note to n00bs (wait a minute... i'm also a n00b): although this example
uses a knob to adjust the PWM, *any* controller(s) can be used.
        ...atom
 ________________________
 http://atom.smasher.org/
	"Man cannot pretend to he higher in ethics,
	 spirituality, advancement, or civilization than
	 other creatures, and at the same time live by
	 lower standards than the vulture or hyena."
		--  H Jay Dinshah, Out of the Jungle
Re: [xl7] real-time, continuously variable, PWM LFOs - #2
as soon as i hit send, i realized that the PWM LFO trick only covered a
range from 50-100% (or 0-50%, depending on how its controlled, used and
how ones brain thinks about such things) duty cycle... how about a way to
do 0-100% duty cycle?
here it is... enjoy...
LFO1:
cords:
  4: MIDI-A  ->  CO3     +98-100
  5: DC      ->  switch  -49-50
the ranges shown for cords #4 & #5 control whether the PWM can be driven
all the way from 0-100% (producing a "flat" output at both ends of the
range) or reeling in the control just a tiny bit to (about) 2-98%
(producing a "blip" output at both ends of the range). either way, this
will output a "standard" 50% duty cycle square-wave at the middle of the
range.
the previous comments about lag processors and other control sources still
apply.
i'm also thinking that if a "random" wave is used from the LFO, this could
be used as a sort of probability generator; spending N% of it's time in
either a high or low state. that might have some useful applications...
         ...atom
 	"A people that values its privileges above its principles
 	 soon loses both."
 		-- Dwight D. Eisenhower
