I saved the pattern (exporting as midifile), called it aup again and the
changes were gone - all notes were back to 0.0.0. I have not found a way
to fix this until now. Is there another way to change the note duration so
it stays like it was changed (sounds rather philosophical...)?
>>>Well, the long way would be to redraw all the notes by hand in the Key
Editor. Honestly I can't figure out why the midifile would revert back to
the way it was. Stupid question I know, but you did save right befroe
exporting right? Also, it's not 100% confirmed, but there might be some
issues with Cubase 5.1 and the MIDI editors that MIGHT be contributing to
this. For more info, go to:
http://linux1723.dn.net/forum/Forum15/HTML/001180.html <<<
Then I tried to load a different one-track-pattern to the mp-7, all notes
longer than 0.0.0. That helps a lot! Still I think, if you have a
16-track-pattern, my mp-7 seems to "forget" many notes even if all of them
are longer than 0.0.0 ticks. Is it possible that in the downloading
process there could be some overflow (my file was 20 k).
>>>How long (measures) is the pattern you're trying to import? <<<<
Another thing: My cubase-pattern was saved with a resolution of 1/480. Is
this compatible to the resolution of the mp-7 of 1/398 (or so) or is this
leading to missing notes?
>>>I don't know, I switched to 1/384 just to be safe. I have a Cubase
Song template I made that I use with the XL-7 for pattern editing, this
was one of the settings I made, in addition to Disabling Audio, deleteing
audio tracks, etc. <<<
Is there a way to change the channel-number of a track in cubase? I
changed numbers, copied and pasted to different tracks, changed
channel-numbers again and so on. All seems fine until I open the file
again and all tracks are set back to the original unwanted setting. There
must be a way how to assign channel numbers in the event-list or so? Am I
wrong?
>>>Sounds like nothing you do in Cubase is saving, which makes this more
of a Cubase problem, and less of an XL-7 one. :) Maybe roll back to an
earlier version (are you using the public betas?), or reinstall it real
quick to see if that helps. Are you using a warez version? Sorry, had to
ask. As for the channels, just changing then on the arrange page should do
it, I've never had any problems with that myself. Have you tried saving
the arrangement as a new name after the changes too? Try that, and
instead of launching Cubase via your desktop icon, try double clicking on
the new arrangement file in Windows Explorer or My Computer. <<<
Sorry, these are more like cubase issues and I try to keep it short. Still
quite a few groupies here seem to use the same sequencer and might like to
know as well may be...
>>>De nada. Cubase is a huge program, there's a lot to learn! Also,
maybe try jumping on the cubase list too and asking about these issues.
Not the best list IMO, but they do have a lot of experienced users on
there. <<<
