not sure exactly what you are saying but the zr-76
rom is good for drums
you best look at the individual wave form list for all the roms
you have that gives a guide to what you can make by layering
up to four of them
the zr-76 rom seems to be mainly drums and perc
once you take out the 50% of the space allocated to the perfect piano
you could get an emulator x and use a laptop with the software
versions instead
Sam
--- In xl7@yahoogroups.com, jason rodgers <fsmastering@...> wrote:
> I like taking my mp-7 only along with me to friends houses and play
along or out to do tracks with but i find that even with the mp-7 rom
and the xlead version 2 rom i need sounds that i do not have access
to. I think i might just need to buy 2 more roms for it but there are
alot of sounds i use constantly ( like drum kits i have made ) that i
would like to have access to. I also have a asr-x with the urban
dance rom which i really like and i think there is a ensoniq rom for
the emu out there but i am not sure if it is the same sounds and i
use alot of the basses and such on that. When you make a rom i am
guessing you gain the ability to use all the patchchord and effects
with it. Was there a way to program in the use of the modulation knob
on the command station? Like some sounds you can add vibrato or fills
to the drums and such? Sorry for so many questions but i am really
into my commandstation and this would be a really nice way to make it
even more usable for me. I
> guess you have to have a ultra sampler and a 32mb rom ( if i can
find one ) Thanks again bob
> "Bob S." <tttsystems@...> wrote: Depends on what you are
trying to do....the closer you are trying to reproduce a known sound
or sound characteristic, the more you have to rely on multi-samples
across the keyboard. For what I wanted, synthesized sounds, no
acoustic instrument reproductions, I used the maximum of 2 samples
per octave. In many cases, I wanted to capture a sound that was
useful only in a very limiting frequency range, so I used 1 or 2
samples for the whole keyboard.....
> Bob
> El Segundo, CA
> -----Original Message-----
> >From: jason rodgers <fsmastering@...>
> >Sent: Apr 6, 2008 2:49 PM
> >To: xl7@yahoogroups.com
> >Subject: Re: [xl7] Re: ROM Authoring Success....
> >Can i ask if you did any keygroups on the rom for instruments and
if so how many sections of the scale did you sample for them? I am
interested in making some roms for my mp7 but have to wonder with the
price of them if it is worth it.
> >"Bob S." <tttsystems@...> wrote: 32MB ROMS, the largest ROM
available, are still sporactically sighted on EBay. I have 2 of the
16MB ROMS from past purchases. I don't believe there is any
compression of sample data, the 15.9MB sample bank that I created on
the sampler was all I could fit on the 16MB ROM. However, some of my
samples were in the range of .5 to 2 seconds in length, much larger
than sometimes is necessary as I was including the portions of the
wave that morphed and changed pitch in time rather than create a
shorter fixed frequency/low modulation loop and let the XL7/PK6/XL1
perform the modulation in real time.....with a few of the factory
ROMS and one or two custom ROMS, there might be every thing I
need.....
> >Bob
> >El Segundo, CA
> >>Sent: Apr 6, 2008 2:14 PM
> >>I have never tried this but what is the largest rom you can make
in the sampler? 32mb. How does the compression work i know you said
you cant fit as many waveforms as the facotry but could you make a
useful rom? Thanks.
> >>"Bob S." <tttsystems@...> wrote: Don't know why I put the letters
ESI in front of the sampler model....the model is an Emu based EOS
sampler, model name E6400 Ultra....but any Ultra of this series will
work.....
> >>Bob
> >>El Segundo, CA
> >>>From: malik <malik_martin@...>
> >>>Sent: Apr 6, 2008 1:49 PM
> >>>Subject: [xl7] Re: ROM Authoring Success....
> >>>TYVM!! i can't wait!!
> >>>--- In xl7@yahoogroups.com, "Bob S." <tttsystems@> wrote:
> >>>> Just to let the group know I was successful in creating my own
sound
> >>>> ROM for my XL7/PK6/XL1 synths using an Emu 16MB Flash ROM and
an ESI
> >>>> E6400 Ultra sampler....the process is not to difficult but
there are
> >>>> some definite things I had to work though which are not that
well
> >>>> documented. The sound set was much more to my music genre but
of
> >>>> course, I maybe was able to put a few dozen waves on the ROM,
nothing
> >>>> like the originals that have 500 to 1000 samples in their 32MB
ROM.
> >>>> When I get a chance, I will repeat and document the process
for the
> >>>> group....
> >>>> Bob
> >>>> El Segundo, CA
> >>You rock. That's why Blockbuster's offering you one month of
Blockbuster Total Access, No Cost.
> >>[Non-text portions of this message have been removed]
