default knob parameters and expansion ROMs
2007-05-24 by D. Clowers
Hi folks, I've been using an MP-7 for a few years now, and love it. One thing that is kind of annoying is that when using an expansion ROM, the controller knob functions do not follow the command station defaults when using presets from that ROM. In other words, it doesnt use the controller functions printed on the box. Instead they are using assignments for a P2K module, and the controller knob assignments are different than on a command station. For instance, on the MP-7, knobs 5-8 are Amp Attack, Amp Decay, Amp Sustain and Amp Release. But if you select a preset from say a WORLD ROM, knob 5 will be Amp Attack, 6 is Amp Release, 7 is LFO Amount and 8 is LFO Rate, like on the front panel of the Planet Earth module. Is there any way to make presets on an add-in ROM use the default command station controller knob assignments? Other than reprogramming the preset and saving it to USER, that is. I havent been able to find an answer in the manual. Any help appreciated. DC
