Using the Mp-7 with Logic 7?
2006-10-31 by primo99mlt
Hi
I recently got an Mp7 and have been learning to use it. I am a
relative newbie when it comes to music production, especially when
it comes to midi and configuring different tone
generators/grooveboxes to sync with pc-based sequencers. I have made
several patterns on the MP-7 that I would like to export[record] to
Logic 7. I do not know where to start really. Would I have to create
an MP-7 enviroment within Logic? I would have absolutely no clue how
to go about this. I do not know what I have to record, whether it be
audio or midi. Does the E-Loader come into the picture at any stage
of the process? I would like to record each sound within the
patterns on a seperate channel, as I am then transferring the audio
from Logic onto a Yamaha DM2000 for mixing and eq/fx [this process
is not a problem as it is already set up]
Sorry for my general lack of knowledge on the subject field, but I
am really keen to get on top of it.
-regards.
p.s. if someone can explain quantizing on the mp7 it would be of
real use as I find the quantization function on the mp7 very
frustrating as compared to the relative ease-of-use of Logic's
[visual aid aside].
Re: [xl7] Using the Mp-7 with Logic 7?
2006-10-31 by Zsolt Szabó
Hello,
if you doesn't plan to edit further the sequences then you just have to
record
audio in Logic.
Create audio track (or tracks), assign input channels where MP-7 is
connected
then solo the wanted channel in the MP-7 by disabling all other tracks in
pattern. Rewind MP-7, press record in Logic, press play on the MP-7,
wait till it recorded at least 2 complete loops
(I alwasy go for 3 complete) then stop. Don't switch off recording after the
last
loop completed if there are any effect tails, like reverbs, delays, etc.
Wait for them to finish.
Select the next track on the MP-7, repeat process on a different audio track
in Logic..
It would be convenient to create a project template for yourself in Logic
for
this if you plan to do it a lot.
Now, you may ask why should you record more loops than one (and by loop
I mean the complete (actual) track length, whatever number of bars it is
The answer is:
- the first loop would be your starting one
- the middle one would be used in the song wherever you loop it, it will
contain
effect tails right on the first beat as well and won't sound unnatural when
you loop it
- the last one would contain both the effect tails from the previous one and
will
let the effects ring out, if any
This is just a recommendation, it's not a must. You decide.
    Zsolt
To: <xl7@yahoogroups.com>
Sent: Tuesday, October 31, 2006 2:05 AM
Subject: [xl7] Using the Mp-7 with Logic 7?
> Hi
> -regards.
> [visual aid aside].
