All channel play
All channel play
2006-10-20 by scodoha04
What I'm trying to do is make a pseudo hammond organ drawbar
arrangement. Having my presets tuned as different drawbar pipe lengths
(16',5 1/3', 8', 4', 2, 2/3', 2', 1 3/5', 1 1/3', and 1) I'd like to
be able to play a keyboard and have the XL7 respond on all channels
with volume controlled by the realtime knobs.
 Is there a way to have all channels respond to the midi input
simultaneously?
Re: [xl7] All channel play
2006-10-20 by Zsolt Szabó
Sure.
Set them all to the same MIDI channel.
    Zsolt
To: <xl7@yahoogroups.com>
Sent: Friday, October 20, 2006 7:20 PM
Subject: [xl7] All channel play
> simultaneously?
2006-10-20 by Aaron Eppolito
Easier would be to make a preset that does this.  Each preset has 4
layers and can link to 2 other presets for a total of 12 layers.  Then,
you could set up patchcords to control each layer's volume with the
MIDI A-N knobs.  This way, you could continue to use the rest of the
box's features (like the sequencer).
Actually, now that I think of it, the preset approach is really the
only way to do it.  I don't think you could have the channels respond
to other channels than what they are.  You could sequence the notes,
then copy them to multiple tracks, not not live.  If your external
keyboard could send 9 channels worth of MIDI it'd work, but that'd be a
hassle.
-Aaron
> lengths
> simultaneously?
Do You Yahoo!?
http://mail.yahoo.com
Re: All channel play
Ahhh! Thanks. Patchcords is the answer. I had thought of the layers
but was stumped as to how to control them.
> hassle.
> -Aaron
> > lengths
> > simultaneously?
> > Yahoo! Groups Links
> Do You Yahoo!?
2006-10-21 by steve_the_composer
I just checked the sysex manual to see if there might be a way to
assign midi channels individually to each of the 32 synth channels.
However, unless there are some undocumented parameters for this,
youi cannot fool the synth engine via sysex.
Aaron once spelled out which parameters the linked presets inherit
from the main preset definition and which parameters they don't. I
think this was part of an explanation of why linked presets sound
different when linked as opposed to when they are used individually.
This might or might not affect your design of your presets.
Your design sounds interesting. Feel free to share the results. I
for one would be interested.
-Steve
layers
has 4
layers.  Then,
respond
notes,
external
that'd be a
> > hassle.
> > -Aaron
> > > lengths
like to
channels
> > > simultaneously?
> > > Yahoo! Groups Links
> > Do You Yahoo!?
2006-10-22 by scodoha04
My hopes have been dashed. I set up a preset with links and filled
the sounds with sine waves tuned appropriately. Setup patchcords to
use realtime controller knobs to adjust amp volume. This didn't work
to adjust the volumes of each voice. Set each knob to midi control 7
but that just makes each knob control the overall volume. The sounds I
have gotten are quite hammondish though. If the xl7 had two more
stereo channels all would be good as the voices can be panned hard and
sent out in six ways and then controlled at the mixer. I'm just shy 3
channels :( My dmpro could handle another 6 channels but I don't have
the sine sound ...yet.
Setting up hardwired drawbar configs seems my only route unless . . .
> -Steve
> layers
> has 4
> layers.  Then,
> the
> the
> the
> respond
> notes,
> external
> that'd be a
> > > hassle.
> > > -Aaron
> > > > lengths
> like to
> channels
> > > > simultaneously?
> > > > Yahoo! Groups Links
> > > Do You Yahoo!?
Re: [xl7] Re: All channel play
2006-10-22 by Aaron Eppolito
Hmm, that should have done it.  The patchcord connection you should make for each layer is MIDI "X" -> AmpVol 100% where X is the knob you want to control that layer.  You'll also want to turn AmpVol to -96dB for all the layers too, so that the patchcord has room to control the sound (i.e. if it's already at 0dB, adding to it won't make it much louder).
Oh, and Steve's comment about parameters for linked presets is correct too.  Initial controller amounts get their values picked up from the main preset, not the linked presets.  Put another way, you'll want to save the controller values (for your layer volumes) in the main preset.
-Aaron
----- Original Message ----
Sent: Saturday, October 21, 2006 5:17:22 PM
Subject: [xl7] Re: All channel play
> -Steve
> layers
> has 4
> layers.  Then,
> the
> the
> the
> respond
> notes,
> external
> that'd be a
> > > hassle.
> > > -Aaron
> > > > lengths
> like to
> channels
> > > > simultaneously?
> > > > Yahoo! Groups Links
> > > Do You Yahoo!?
Yahoo! Groups Links
2006-10-22 by steve_the_composer
1a. Try assigning each knob (MidiA through MidiP to a different CC.
For example:
REALTIME CONTROLLER#
A: 70 B: 71 C: 72 D: 73 etc.
1b. Or you could just use your current [or the default] values.
For example:
A: 74 B: 71 C: 25 D: 26 etc.
2. Then, in each layer, assign a different knob/CC to AmpVol.
For example:
L1 PATCHCORDS #01 [of main preset]
MidiA --> AmpVol +30
L2 PATCHCORDS #01 [of main preset]
MidiB --> AmpVol +30
L3 PATCHCORDS #01 [of main preset]
MidiC --> AmpVol +30
etc.
--Steve
(1) Thanks for the clarification on the linked presets, Aaron.
(2) I just tested the theory of my previous post about using
different CC#s. (I am using the knobs in Quick Edit Mode). It works
with L1 through L4 set up to Sinusoid wave (on the P2500) with L1 @
Course +00, L2 @ Course + 12, L 3 @ Course + 19, L 4 @ Course +24.
Don't worry about changing CC numbers as I suggested as one option.
Whatever CCs your E-Mu is set up to use should work, so long as you
don't have MidiA through MidiP assigned anywhere else (layer or
preset patchcords).
As Aaron suggested, lower APLITUDE to -96dB. You can then set MidiX --
>AmpVol +100 and have the full range of the knob.
Hope this helps.
--Steve
the main preset.
> -Aaron
> From: scodoha04 <scott.d.harvey@...>
> To: xl7@yahoogroups.com
sounds I
and
3
have
unless . . .
channels.
inherit
I
individually.
> > -Steve
> > layers
> > has 4
> > layers.  Then,
with
> > the
of
> > the
really
> > the
> > respond
> > notes,
> > external
> > that'd be a
> > > > hassle.
> > > > -Aaron
drawbar
pipe
> > > > > lengths
I'd
> > like to
> > channels
input
> > > > > simultaneously?
> > > > > Yahoo! Groups Links
> > > > Do You Yahoo!?
around
2006-10-24 by scodoha04
I was having other strange things occur so decided to reload the
sytem. Don't know if that was it but got the project working somewhat.
The linke set was responding to both the patch and the realtime cc
settings.I think toggling the disable/enable controller knobs with
their values set at 0 cleared it. Not sure if this makes sense cause
troubleshooting protocol was out the window at that point.
  The volume envelope for a constant on while key pressed would be
what? ( atk1@100 dcy2@100 and all else @ 0 )?
> preset patchcords).
> Hope this helps.
> --Steve
> the main preset.
> > -Aaron
> > From: scodoha04 <scott.d.harvey@>
> sounds I
> and
> 3
> have
> unless . . .
> channels.
> inherit
> I
> individually.
> > > -Steve
> > > layers
> > > has 4
> > > layers.  Then,
> with
> > > the
> of
> > > the
> really
> > > the
> > > respond
> > > notes,
> > > external
> > > that'd be a
> > > > > hassle.
> > > > > -Aaron
> drawbar
> pipe
> > > > > > lengths
> I'd
> > > like to
> > > channels
> input
> > > > > > simultaneously?
> > > > > > Yahoo! Groups Links
> > > > > Do You Yahoo!?
> around
> > Yahoo! Groups Links
