New owner ... pattern record and cubase ... bug???
2002-02-09 by grimleyj2000
I just got a XL-7 and immediately upgraded to 1.18. I am having problems when I have the XL-7 synced to Cubase and I want to jump into grid record mode (hold play then hit record). The XL-7 will only allow me to record with the preset from the track I originally had selected. So for instance I start with track 9 for bass and I then change to track 1 for kick, it will only record more bass notes even though the pads are playing the kick when I hit them. It gets worse .... I hit stop on Cubase then RTZ the XL-7. Then I go back into grid record on the XL-7 without starting Cubase. I have the same problem ... it is still recording bass notes even though I have selected track 01A for kick. Changing pattern and recording from there does not fix it. I have to reboot the XL-7 then everything is OK ... until I sync to Cubase again of course. Is this a MIDI issue or a horrible bug? Second problem ... when in step record ... how to I go back a step? I know I can go forward by hitting Play but ... And lastly ... in realtime record, what is the easiest way to delete or overwrite a bum note when recording in a loop? Thanks for your help, Justin.
