RATING @ SONICSTATE
2002-02-07 by www.mp3.com/koering
2002-02-07 by erik_magrini@Baxter.com
I think a lot of that reflects the earlier bugs in the OS. read the
reviews, you'll see what I mean. Most of the complaints are fixed by now.
"www.mp3.com/koering" <A.Libi@...>
02/07/02 04:09 AM
Please respond to xl7
To: <xl7@yahoogroups.com>
cc: Subject: [xl7] RATING @ SONICSTATE hey whats up.... 3.7???? well, I think the XL-7 is a 4.5 worth.....maybe we should rate them a little bit better.... http://www.sonicstate.com/synth/emu_xl7.cfm Yahoo! Groups Sponsor ADVERTISEMENT To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
----- Original Message -----From: erik_magrini@...Sent: Thursday, February 07, 2002 2:15 PMSubject: Re: [xl7] RATING @ SONICSTATE
I think a lot of that reflects the earlier bugs in the OS. read the reviews, you'll see what I mean. Most of the complaints are fixed by now.
"www.mp3.com/koering" <A.Libi@...>02/07/02 04:09 AM
cc:
xl7-unsubscribe@...m
2002-02-07 by Jonathan El-Bizri
----- Original Message -----From: www.mp3.com/koeringSent: Thursday, February 07, 2002 6:14 AMSubject: Re: [xl7] RATING @ SONICSTATEthat´s right...but most grooveboxes got bugs.....some mor some less......but emu goes the right way... good hardware.... and well software with some bugs, which can be fitted....does anybody knows when the next update will arrive?would be cool if I could start the engine with the last pattern... so i don´t have to scroll each time....----- Original Message -----From: erik_magrini@...Sent: Thursday, February 07, 2002 2:15 PMSubject: Re: [xl7] RATING @ SONICSTATE
; To: <xl7@yahoogroups.com>
cc:
----- Original Message -----From: erik_magrini@Baxter.comSent: Thursday, February 07, 2002 6:21 AMSubject: Re: [xl7] RATING @ SONICSTATE
>>>Supposed to be end of February, early March. Emu? <<<
>>>save a copy of it to User Bank 0, Pattern 000. <<<
2002-02-08 by nifflas
I don't think it deserves 4.5 - I would now give it 1 because I had to pay more money for buying it when the OS was in beta state. Now it works better, and it's cheaper. This is what "Giotto" said about the XL-7, and I agree 100% - the sounds is amazing, but the sequencer is strange and doesn't really make sense. >Big problems and reason's why I took mine back: The channel assignments are all out of whack. There is an option to assign a given midi channel to be either sent to internal/external/both or none, and when playing into the XL-7 via it's pads or an external controller, these very important settings have no effect. In other words, while playing into the XL-7 both the internal sounds and the external sound sources you have midi'd up will play according to your input EVEN if you have the Channel Assignments locked to play the internal sounds only. Once you Do record in your part the Sequencer pays attention to the int/ext/both assignment and does correctly send your midi signals to the proper sources either internal or external, but its a total pain to have to constantly turn volumes up and down so you can SHUT a synth up long enough to record your part without extraneous chatter from "unassigned" instruments. This is a BIG booboo on the part of EMu's programmers.
