(not installed) ???? please help!!!!
2005-10-01 by eriksatie01
what's happening here?
today I turned on my xl-7 and many of may patterns was corrupted. may
traks are not correctly assigned to its preset. Insted of the name af
the right preset,a message says (not installed).
Moreover, if I re-assign the right preset to the track, and then save
it again, this assignement go lost when I recall the pattern!!
I've tried to save the preset to another location, to save the patter
to another location, to move the track to another track number without
success.
plese help me, I fear that all those tries with sysex uploading has
caused some damage to my machine and to my work!
davide
Re: (not installed) ???? please help!!!!
2005-10-01 by malik
holy shit. whats whole defragmenting thing the command station can do?
maybe that will help. maybe you should wait for a better opinion.
> success.
> davide
alredy tried...
it tells me that there's no need to do it and it doesn't do nothing...
please doctor, tell me... is it serious?
> > success.
> > davide
2005-10-01 by gonzinigonz
Its possible that the internal memory has been corupted whilst trying
to send sysex to it, seeing that you've had so hassle trying to get
it to work. (command station timming out and stuff)
Have you backed up your patterns via E-Loader?
As you dont seem to have a midi in on your PC i guess you havant been
able to back up your sound banks?
It would of been good if you could of done this before things went
bad, as now it looks like you might have to reset the machine.
I think thats what you might have to do if its playing around with
you.
Also you need to get a proper midi interface for your PC as you have
to back up data. Its a computer and not the most reliable one at
that..
Maybe someone else here has a better idea?
Gonz
> alredy tried...
nothing...
can do?
corrupted. may
name af
then save
patter
without
> > > success.
has
> > > davide
Sure I have to buy a midi interface to back up things!
since now I haven't do back up, and I will never try again to send
sysex without doing back up before!
now the question is: do you think that a reset would give me back my
xl-7 as before, or memory has became phisically corrupted?
thx
> you.
> that..
> Gonz
> > alredy tried...
> nothing...
> can do?
> corrupted. may
> name af
> then save
> patter
> without
> > > > success.
> has
> > > > davide
RE: [xl7] Re: (not installed) ???? please help!!!!
2005-10-01 by Chris
check if you have disabled the midi-channel..
the patter loads up with a program change command, so if you have midi
disabled for this track (i.e. when using an external synth in another
song and not changing it back) it might happen that the right pattern is
not loaded..
try enabling all midi channels, then press the stop button 3 times to
reset the pattern (or simply change the pattern and go back to it again)
From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf Of
eriksatie01
Sent: Samstag, 1. Oktober 2005 22:02
Subject: [xl7] Re: (not installed) ???? please help!!!!
thx
> you.
> that..
> Gonz
> > alredy tried...
> nothing...
> can do?
> corrupted. may
> name af
> then save
> patter
> without
> > > > success.
> has
> > > > davide
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "xl7 <http://groups.yahoo.com/group/xl7> " on
the web.
*	 To unsubscribe from this group, send an email to:
<mailto:xl7-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
ooops yes your right Chris, bit less hectic than starting again..
cool, you wont regret it
always..
Well you will lose your sound banks as i dont think theres a level of
reset that will leave them intact.
The other level of reset will leave the user pattern data untouched,
but if this is were the problem is then you wont have much choice.
As long as the unit dosent have other hardware problems a reset
should get things back to a clean slate.
You will have to reload sound bank data though.. think the presets
get copied over to the user banks when you reset.
Also if you do the whole memory reset the pattern data will have to
be loaded back as well. Seeing that your having problems with this..
Id get a midi interface before doing anything and atempt to back up
whats there. If the problem reappears after a successful reload then
theres yopur problem. you might be able to track it down to 1 rogue
patten or sound patch (more likely to be a pattern in that case..)
Ive come accross this of problem before with other gear (akai..)
Hopefully its a problem like Chris has mentioned
be carefull eh
Gonz
midi
another
pattern is
> not loaded..
to
again)
> -----Original Message-----
> eriksatie01
> To: xl7@yahoogroups.com
> thx
trying
get
been
went
with
> > you.
have
> > that..
> > Gonz
> > > alredy tried...
> > nothing...
station
> > can do?
opinion.
> > corrupted. may
> > name af
> > then save
pattern!!
> > patter
number
> > without
> > > > > success.
uploading
> > has
> > > > > davide
>   _____
> YAHOO! GROUPS LINKS
on
> the web.
>   _____
Re: [xl7] Re: (not installed) ???? please help!!!!
2005-10-02 by Aaron Eppolito
If you think your global options are set to strange values, reset them
by simply restoring the factory multisetup (#63).  Remember that if you
don't have sequence data on a track (i.e. a note or controller or
something) it won't save the preset for that channel.  That's by design
(though a choice I regret considering how many people it's confused).
-Aaron
PS. compacting memory will never fix anything.  It's only to defragment
memory before going out live so that compaction doesn't run
automatically while you're in the middle of your set.  If it says it
doesn't need it, it really doesn't.
> always..
> be carefull eh
> Gonz
> midi
> another
> pattern is
> > not loaded..
> to
> again)
> > eriksatie01
> my
> > thx
> trying
> get
> been
> went
> with
> > > you.
> have
> > > that..
> > > Gonz
> wrote:
> > > > alredy tried...
> > > nothing...
> station
> > > can do?
> opinion.
> > > corrupted. may
> the
> > > name af
> > > then save
> pattern!!
> the
> > > patter
> number
> > > without
> > > > > > success.
> uploading
> > > has
> > > > > > davide
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
fs : xl7
2005-10-03 by moose
fs : emu xl7 with **as new** rack ears, original manual and power cable.
perfect condition.  $400 plus shipping from LA.  personal / cashier cheques
are fine, though paypal will incur a 3% charge to cover their costs.
email me off list if you, or someone you know, is interested.
email :
  moose@...
music sites :
  http://www.pigpendigital.com
  http://www.alaskahighway.com
  http://www.mishikawa.com
2005-10-12 by eriksatie01
ok guys, NOW I have a "real" midi interface. It is my old creative
Live! gold, it has two real midi port and a digital in/out. I haven't
bought anything because I'm planning to buy a new firewire interface
with audio and midi all in one.
I tried it with e-loader and it works properly.
I also tried to upload the un-famous banks from Rob Papen and all
went perfectly! at first strike! how many time spent on that, and the
solution was simple...
So I've learnt three important thing:
1. the midi out of my evolution keybord sucks
2. never send sysex with a sucking midi out
3. never send sysex before doing a back-up
Now I've solved the problem the upload those rob papen banks, but as
you know I have a new one: my sequences are corrupted and my xl-7
doesn't work properly. So I will back up everything and then reset
the machine. How can I reset it? I haven't found this anywhere in the
manual.
thx
them
you
design
confused).
> -Aaron
defragment
send
> > always..
back my
level of
untouched,
presets
to
this..
up
then
rogue
> > be carefull eh
> > Gonz
have
> > midi
> > another
> > pattern is
> > > not loaded..
times
> > to
it
> > again)
Behalf Of
> > > eriksatie01
send
back
> > my
> > > thx
whilst
> > trying
to
> > get
havant
> > been
> > went
> > with
> > > > you.
you
> > have
at
> > > > that..
> > > > Gonz
> > wrote:
> > > > > alredy tried...
> > > > nothing...
> > station
> > > > can do?
> > opinion.
<waveplayer@t...>
> > > > corrupted. may
of
> > the
> > > > name af
and
> > > > then save
> > pattern!!
save
> > the
> > > > patter
> > number
> > > > without
> > > > > > > success.
> > uploading
> > > > has
> > > > > > > davide
Evolution
2005-10-12 by steve_the_composer
Based on our conversation, I picked up a used evolution (on ebay). I
see the problem first-hand with the lack of midi in. Using the
SB/Creative midi i/o should solve your original problem.
As for the evolution, the usb midi out and the regular midi out seem
to work just fine. However, the keyboard "sucks" (IMO, to borrow
your phrase). It has the feel of a cheap toy electronic keyboard.
(You know--the ones with the speakers built in.) I tried all of the
keyboard velocity scalings, and have not found one that works for me
with heavy springs of the unit. (The knobs are nice, though; but the
button/display seems quirky.)
If you like the feel of the evolution and the midi out-->usb works
for you, you should still be able to used the SB midi in (as long as
the card doesn't have any conflicts).
(I hope no one takes my purchase of the evolution as an endorsement.
It seemed like a decent price to test it out. It may still work for
taking around to schools, doing arts-in-education stuff, and for
note entry/composing. As of now, I don't see using it for serious
performance. Well, maybe for turning on beats, arpegiators, etc.)
--Steve
BTW, you can use e-loader's midi monitor to test both the usb and
midi outs of the evolution.
haven't
interface
as
> manual.
> thx
reset
> them
if
> you
> design
> confused).
> > -Aaron
> defragment
says it
again..
> send
> > > always..
> back my
> level of
> untouched,
choice.
> presets
have
> to
> this..
back
> up
reload
> then
> rogue
case..)
(akai..)
> > > be carefull eh
> > > Gonz
> have
> > > midi
in
> > > another
right
> > > pattern is
> > > > not loaded..
> times
> > > to
to
> it
> > > again)
> Behalf Of
> > > > eriksatie01
to
> send
> back
> > > my
> > > > thx
> whilst
> > > trying
trying
> to
> > > get
> havant
> > > been
things
> > > went
machine.
around
> > > with
> > > > > you.
as
> you
> > > have
one
> at
> > > > > that..
> > > > > Gonz
> > > wrote:
> > > > > > alredy tried...
do
> > > > > nothing...
> > > station
> > > > > can do?
better
> > > opinion.
> <waveplayer@t...>
was
> > > > > corrupted. may
Insted
> of
> > > the
> > > > > name af
track,
> and
> > > > > then save
> > > pattern!!
to
> save
> > > the
> > > > > patter
track
> > > number
> > > > > without
> > > > > > > > success.
sysex
> > > uploading
> > > > > has
> > > > > > > > davide
Re: Evolution
I will use it only as a midi controller, but I don't like it very
much neither. keyboard is really plastic, buttons are not well
aligned, and it lacks of usefull function such as saving controllers
assignement, or split the keyboard. I think i will change it with
something smaller and of better quality, when I'll have the budget
for that!
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
I
seem
me
as
endorsement.
> --Steve
creative
> haven't
> interface
> the
> as
reset
> the
> > manual.
> > thx
> reset
> > them
that
> if
> > you
or
by
> > design
> > confused).
> > > -Aaron
> > defragment
> says it
> again..
to
> > send
> > > > always..
> > back my
> > level of
> > untouched,
> choice.
reset
> > presets
> have
> > to
> > this..
> back
> > up
> reload
> > then
> > rogue
> case..)
> (akai..)
> > > > be carefull eh
> > > > Gonz
you
> > have
> > > > midi
> in
> > > > another
> right
> > > > pattern is
> > > > > not loaded..
3
> > times
> > > > to
> to
> > it
> > > > again)
> > Behalf Of
> > > > > eriksatie01
> to
> > send
me
> > back
> > > > my
> > > > > thx
> > whilst
> > > > trying
> trying
> > to
> > > > get
> > havant
> > > > been
> things
> > > > went
> machine.
> around
> > > > with
> > > > > > you.
> as
> > you
> > > > have
> one
> > at
> > > > > > that..
> > > > > > Gonz
<waveplayer@t...>
> > > > wrote:
> > > > > > > alredy tried...
doesn't
> do
> > > > > > nothing...
command
> > > > station
> > > > > > can do?
> better
> > > > opinion.
> > <waveplayer@t...>
> was
> > > > > > corrupted. may
> Insted
> > of
> > > > the
> > > > > > name af
> track,
> > and
> > > > > > then save
> > > > pattern!!
> to
> > save
> > > > the
> > > > > > patter
> track
> > > > number
> > > > > > without
> > > > > > > > > success.
> sysex
> > > > uploading
> > > > > > has
> > > > > > > > > davide
2005-10-13 by Mibrilane
> manual.
RESET is done from the diagnostics menu - hold down both cursor keys (left &
right) while turning on the unit - it will go do diagnostics mode. Then
scroll to the very end - the reset command is there.
Hope that helps. I don't have my XL at the moment to check this but I
believe I'm remembering it correctly...
Mibrilane
2005-10-13 by Aaron Eppolito
Please, please, please - don't recommend full resets to people having
problems!  You will ERASE ALL YOUR SEQUENCES!  The diagnostics menu
isn't documented because you're really not supposed to be in there.
For fixing odd problems like the kind you're having, first try
reloading the factory multisetup.  This will reset everything in the
Global menu and MIDI menu to reasonable values, solving things like not
changing presets, messed up MIDI settings, etc.
1 - Global menu > 1st screen: RESTORE MULTISETUP
2 - cursor down and scroll to: 063 Factory Setup
3 - press enter
If this doesn't solve your problems, the second step would be to reset
all except seq in the diagnostics menu.  It's the third to last item.
Note, however, that this will ERASE ALL EDITED PRESETS!  This really
should only be used to reset presets, as that's the only additional
thing it does beyond restore the factory multisetup.
The ONLY time you should ever perform the second to last diagnostic
reset is if you want to ERASE EVERYTHING from the box, INCLUDING
FACTORY SEQUENCES.  Really this should only be done with a newly
aquired used unit that has a lot of junk sequences and you don't want
any factory sequences.
Sorry, not to pick on anybody here (and I know you're trying to be
helpful mibrilane) but casually suggesting an unsuspecting user to
delete everything from their XL-7 can cause problems.  It's like
saying, hmm, sounds like you have a computer virus - I don't really
remember the specifics, but I think you should type "format c:".
-Aaron
> as
> the
> > manual.
> (left &
> Then
> Mibrilane
Yahoo! Music Unlimited
Access over 1 million songs. Try it free.
http://music.yahoo.com/unlimited/
I get that Aaron, but he asked how to do the RESET. He's backing up his data
before he does it, so I assumed he knows what it does. It's not like he said
he's having weird glitches and asked a generic "what should I do?" He
specifically asked how to do the RESET after backing up his data, and I
answered that question.
The more appropriate computer analogy would be a computer user saying
they've backed up their computer and asking "how do I reformat my hard drive
for a fresh install of Windows?"
It's good that there are other troubleshooting steps to try, though - thanks
for sharing them. :D
Mibrilane
2005-10-13 by eriksatie01
No probs here guys :)
I've backed up everything, I've done the full reset and uploaded
everything back. all went fine and it seems that the problem has been
solved. with two minor disadvantages:
1. sometimes I still get this "not installed" massages, but less than
before. this is strange because usually you solve or you don't solve
something. this is a strange half way... but is better than before
2. I've lost all the factory patterns. didn't consider it. but I hope
I will find them easy, right?
before resetting, I've tried to restore factory multisetup but with
no success. I really don't understand what's happened to my
sequences, I think something about program change messages. Is there
something I have to inspect to check this?
really
his data
He
and I
saying
hard drive
though - thanks
> Mibrilane
2005-10-13 by gonzinigonz
---> No probs here guys :)
Cool!
>been solved. with two minor disadvantages:
>than before. this is strange because usually you solve or you don't
>solve> something. this is a strange half way... but is better than
>before
sounds like theres still something amiss. What roms do you have
installed? Have you cleaned the connections on the offending rom?
Be careful if you try this, static dischrge is a killer for sensitive
electronics. Always make sure you have earthed yourself so that you
are not charged before handling it. (or the insides of your command
station..)
hope  I will find them easy, right?
Think there in the files section. If not then im sure we could send
you the file to download into you unit. Ive got CD that came with the
protean rom thats got most stuff avaible for these units on it from
emu.
>there something I have to inspect to check this?
Maybe its related to you patterns losing the patches in that there
could be a hardware problem and its corupting the memory somehow.
I would of tryed starting a fresh with non of your original data
loaded to see how stable the unit was.
Maybe just load the factory sound banks back in.
Then if things seem ok start loading back in parts of your data to
see if problems started to appear.
You have to remember that if you original data is corupted then all
you would of done by loading it back in is loaded the problem back in
as well! (ive been here with other units...)
Like Aaron says its not always the best solution to totally reset the
unit but its the only real way of getting back to a clean slate so
you know where you are with things.
But saying that ive had to FORMAT:C a few times in the past. I never
regretted doing that after the event, as it was more productive than
spending hours banging my head against the wall trying to sort
windows out.... aaarrrgghhhhhhhhhhhhh
just a few ideas anyway..
Gonz
be
to
> really
up
> his data
do?"
> He
> and I
> saying
> hard drive
> though - thanks
> > Mibrilane
> >before
> station..)
the problem happens only with user presets, not with sounds from the
roms. But user presets seems to be ok: if I select them from a new
pattern and save the pattern, then the presets are recalled in the
right way. the problem happens always with the same patterns and in the
same tracks: everytime I load them, I have this (not installed) instead
of the right preset. if I change preset with the right one and then
save the pattern, the next time this assignement is lost and I get (not
installed) again
that's why I think there is something corrupted in the pattern data.
could someone explain me how presets are linked to patterns?
I thought it was done with program change, but in the midi controller
editor I cannot see any program change at all. Maybe is it simply hide
in the editor? I can I edit this?
thx
2005-10-14 by gonzinigonz
Hi
Does sound like something with your pattern data then..
I forgot where the original problem stemmed from.. (dont think you
need to pull your machine appart and start cleaning connections..)
These messages are present in all command station generated patterns
before the first bar starts (if i recall correctly..)
(In this order in the cubase list editor)
Main Volume (controller No. 7)
Pan (controller No. 10)
Control 79 (controller No. 79) is hard coded to MIX Ouput parameter
Genpurp5 (controller No. 80) is hard coded to ARP status parameter
BankselMSB (Bank select MSB, controller No. 0)
BankselLSB (Bank select LSB, controller No. 32)
Progchange (its own channel message, not part of the 127 controller
messages..)
As you can see there is the program change message and the important
bank selection mesaages as well (to select the correct rom)
I think this info is only transmitted when the pattern is called up
so it doesnt keep resetting things.. (correct me if im wrong..)
Check to see that these are present in your patterns that are playing
up.
And yes it dosent show up in the EVENT editor in pattern edit.
It seems that they are a part of the internal patterns (before the
start of the first bar) and are hidden
from you unless you add some new controller data / program change,
then they should appear in the event listings on the command station.
If you export them as midi files they show up in an editor
I think you will have to open up the mid files on your PC with cubase
or other sequencer.
This could also be a way of salvaging the note data from the
offending patterns as you could edit / delete the progam change /
bank select data and maybe transfering them back and resaving them on
the command station with the correct patches (or even saving it in
cubase etc)
Not sure where the 'not installed' message originates from as ive not
see that one. Maybe Aaron can shed some light on that one?
You can always send me 1 of the patterns (mid file)
gonzini@... and l'll dissect and try to see whats going on..
Also i have the orignal XL7 (and others..) pattern banks here if you
wanted them
Hope that helps
gonz
instead
(not
> installed) again
controller
hide
> thx
2005-10-14 by eriksatie01
> messages..)
THIS is interesting!
now I know what I have to check. thx very much, exactly what I needed!
2005-10-14 by Aaron Eppolito
If you want to see the events in the event viewer, temporarily set the
track to external.  When set to internal, it hides the events that it
puts in at tick 0 so that the casual user doesn't delete events that
the sequencer puts in there.
If you want to fix the program changes, however, you don't have to use
the event editor at all.  Just set up the presets with the main screen
and resave the pattern.
-Aaron
> patterns
> > messages..)
> needed!
> Life without art & music? Keep the arts alive today at Network for
> Good!
> http://us.click.yahoo.com/iuUuID/dnQLAA/n1hLAA/pWZylB/TM
Cheers Aaron thats alot easier. Just kepted forgetting to set the
track back to internal.. And hitting enter each time..
Ive seen the 'not installed' message myself now
Its when it trys to call up a preset / rom thats not there (suprise
eh?!)
So theres the problem then. Not quite sure why when it was re-saved
with the correct presets it didnt work, but if the've been corupted
then maybe thats the problem with that.
For Erick-
so for EVENT edit window (with track assigned to EXT..)
C1 Prog:1 m:0 I:2
<< means >>
Ch# 1 preset 001 m:user preset area (MSB) I:bank 2 (LSB)
m: = ROM so val:-
0 = user prest area
14 = XL7
19 = Protean Drum
65 = Techno
67 = Beat Garden
This is as my machine you might have differant roms installed.
Check that these values are present (or the ones that you have) or
you will get the 'not installed' message.
So (mode/view) PRESET --- AUITION will give you the ROM No. (m: MSB)
and Bank No. (I: LSB)
Hope that helps, ive needed to go through it myself..
Gonz
it
use
screen
> -Aaron
> > patterns
parameter
parameter
controller
> > > messages..)
> > needed!
2005-10-26 by dwoodaman
True enough, be careful! My XL freaked out in a big way, but the
simple procedure Aaron details worked perfectly! I am so glad the
group is still here!
> 3 - press enter
> -Aaron
> --- Mibrilane <mibrilane@c...> wrote:
> > as
> > the
> > > manual.
> > (left &
> > Then
> > Mibrilane
