trouble sending sysex
2005-09-26 by daxe
I dont know if any of this will help you, but I had a terrible time getting my Ensoniq FIZMO to take an OS update through my gear and this is what I did:
I tried another midi interface..this one hooked up through USB.  The first interface I used was through my JLCooper MSB REv2+, which mangles everything sent through it.  I tried an Edirol UMX thing next.  I tried a bunch of programs but always got only a partial upload.
I had a little better luck when I removed everything else off that USB bus...it got almost all the way through but the data was still coming too fast.  FIZMOs are notorious for chiking on too-fast midi data (as well as bad voltage regulators).
What I finally had to do was send the sysex one chunk at a time from sounddiver.  The combo of this method, plus the USB interface not being 'interrupted' by other things on the same bus allowed me to get the sysex finally uploaded.
Some devices are crankier about the integrity of the midi data than some others, I guess.
Hope this helps, maybe give you some ideas.
~snakefooot
Do You Yahoo!?
http://mail.yahoo.com
Re: trouble sending sysex
2005-09-26 by eriksatie01
I have the same feeling that could be something about the midi
interface. I will try to disconnect eveything off from usb.
but what do you mean with "send the sysex one chunk at a time from
sounddiver"?
how can you send midi directly from the sounddriver? how do you
divide the chunks?
this evening I will try also with mediaplayer, and I think I will
check if there is some update for the drivers
thx to everybody for the help!
davide
this is what I did:
upload.
> ~snakefooot
> Do You Yahoo!?
2005-09-26 by steve_the_composer
Hope you can get it resolved. BTW do you have an "old-fashioned"
sound card with a joystick port in your system? If so, perhaps you
could use it (with a midi/joystick cable which are dirt cheap now.
Sysex and midi were pretty straight forward pre-windows, and while
Windows makes everything else possible, there is so much overhead
that G-d knows what's happening to the byte-by-byte midi stream.
Anyhow, it sounds like you need to do some serious diagnosis,
starting with the simplest possible midi flow and the simplest
possible tests. (eg, get a setup so you can send one preset to the
computer and receive one preset from the computer.)
To test sending and receiving you could try midi-ox or even e-
loader's midi monitor. In fact, try it with patterns and e-loader.
Can you successfully get the names of a bank of patterns?  If so,
sysex is working. If not, you've got a problem from the get go.  Can
you download and upload patterns in e-loader? If you can, sysex is
working. If not, you gotta work on the basics.
In using e-loader, when you scan for midi devices, does the e-mu
show up (using the midi connection, not the usb host connection]?
Of course, if the windows media player thing will work off the bat,
or if trying a different interface will work, great!!!
Good luck.
--Steve
Hmmmm. Just an afterthought--try some different cables.  Every so
often I've gotten a cable that seems to work at least 99% of the
time, but is 1% defective for some reason.
> sounddiver"?
> divide the chunks?
> davide
time
> this is what I did:
which
> upload.
that
midi
to
than
> > ~snakefooot
> > Do You Yahoo!?
2005-09-27 by eriksatie01
the fact is that my evolution keyboard (that is also my midi
interface) only has a midi out, so I cannot record midi flow on my
computer, and I cannot do some usefull test like dump sysex from my
xl-7 to pc and back.
but I still have several things to check. hope this evening I will
find some time to try.
surely I will keep you informed about it!
thx
davide
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
Can
> Good luck.
> --Steve
from
> > sounddiver"?
> > divide the chunks?
> > davide
> time
> > this is what I did:
USB.
> which
> > upload.
> that
still
> midi
interface
me
> to
> than
> > > ~snakefooot
> > > Do You Yahoo!?
