Song construction tips?
2005-07-25 by zerocrossing2001
Hi.
I've been using drum machines for years, and for the last 12 or so I've synced audio
loopers (Lexicon JamMan and Electrix Repeater) to them. It's always worked great (and still
does) but I think I use my drum machines in a somewhat non traditional way.  I use either
a Korg Electribe ESX-1 or E-MU XL-7 to put together dense loops and then kind of
randomly mute/unmute tracks while in song mode.  The lack of traditional song structure
is great for the way I like to improvise.
Well, this weekend I decided to put together something with a more "pop" structure and I
found the song modes on both the above drum machines to be SO awkward compared to
a DAW like Digital Performer or Logic, I ended up with nothing.
So, am I just spoiled by modern computer sequencing... or am I approaching the drum
machine song construction in the wrong way?  My idea is to avoid having to bring a laptop
to gigs, but if it's going to be so much easier I'll do it.  I can get around pretty quickly in
Digital Performer 4... then I started to think "well if I'm bringing a laptop for sequencing,
why not use it as a sound source as well?"  The ESX-1 is a sampler and the XL-7 is a
ROMpler so it's not like I'd have issues with a laptop not being able to have fast enough
processors.
So, if there's a song construction tip that you can think of, I'd love to hear it.  If you've
found a better tool that lets one work more intuitively, (the Electribe has a way better
interface than the E-MU IMO) I'd like to hear that as well.  If song construction in modern
drum-machines is just a big pain compared to software, than I guess I'll abandon my little
yellow boy for my current project, or use it purely as a sound generator.
Mark
RE: [xl7] Song construction tips?
2005-07-26 by Daniel Jarvis
Mark
The way i do song structure, is to learn the structure of a particular
musical style i want to work with.
For example i am studying classical indian music.  ive had my xx7 for about
a month now and have begun to set up patterns that conform to the musical
style.  I dont look for the patterns to be already in the machine,  but
rather, first know the music well enough; then know the xl7 well enough to
emulate that style.  my 2 cents
Dan
Re: Song construction tips?
2005-07-26 by robotchas
--- In xl7@yahoogroups.com, "zerocrossing2001" <zerocrossing2001@y...> wrote:
Hi Mark,
I responded to your private email, but here are some more specific tips for working with
pattern-based sequencing (as opposed to linear sequencers like a DAW):
Think in sections. In a typical pop song the sections might be Intro, Verse, Chorus, Break,
Bridge, Outro (not exactly in that order); some sections will repeat and some will change
the second or third time around (Chorus2, Chorus3, for instance).
Make a separate pattern for each section. Often you can just duplicate a section and add
or modify tracks to get the next section. For instance, the Chorus may have a different
bassline than the verse and the hihat pattern may change, but the kicks might be the
same.
You can make each pattern the full length of the section, or loop a shorter pattern the
necessary number of times.
Use the trigger buttons and the pattern select mode to switch patterns/change sections as
the song progresses; for transitions, you can unmute a snare fill, build the transition into
the last measure of the pattern (if the pattern and the section are the same length), or
insert a short transition pattern in between sections.
You can do this manually and try different arrangements - a longer last chorus, a break
between the first chorus and the second verse, whatever - or build it as a song (basically
just a chain of patterns). Songs can include mute events to automate things like bringing
in a snare fill at the end of the verse. I generally leave stuff in pattern mode, and use song
mode only when I'm getting ready to record.
You can also use XMIX to experiment with different transitions or try using the chorus
bassline with the verse, etc.
Hope that helps.
Charles.
2005-07-26 by BEAUFILS Adrien
I think it's a good way to create song to use an software sequenceur but to slave your xl7 but you will still have to create your presets. So my way is to sequence in the xl7 and after to compile these sequences in a software.
That my point of view.
Bye
 Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
 Téléchargez le ici !
2005-07-26 by mike
I don't know how much this will help you. but I had a friend record guitar on my digital
recorder a while back.  Then I sync'd my px-7 to it.  I attacked the guitar track one pattern
at a time.  I can't remember exactly, but it was something like 7 or 8 patterns when I
finished.  I chained them in song mode and it worked perfectly.  Not knowing much about
drums, let alone music, it sounded ok.  It didn't take much time at all, which surprised me.
If you want to hear it go to:
http://f1.pg.briefcase.yahoo.com/mikedancy
Look in the "Old Stuff" folder for a track called "Original Song Draft"  I definitely could have
been more creative with the drums, but you'll get the idea.
Mike
> Hi.
still
either
structure
I
to
laptop
> processors.
modern
little
> Thanks,
> Mark
2005-07-26 by zerocrossing2001
That's not quite the answer I was looking for (perhaps I should have better worded the
question), but good sound advice.
--- In xl7@yahoogroups.com, "Daniel Jarvis" <danieljtb@h...> wrote:
> Mark
> Dan
That is actually exactly what I was looking for.  I think my problem is I've gotten used to
linear sequencers and it's a bit of a mind flip to think in a pattern based mode.  I'm going
to hunker down and work on this more tonight.  Thanks so much!
Mark
> Hi Mark,
Break,
> same.
as
into
bringing
song
> Hope that helps.
> Charles.
Yeah, I may end up using a hybred style of programming patterns on the xl-7 and then
bringing them into the computer for song construction.  I worked on this last night and it
seemed to be a great workflow.
Mark
> Bye
That does sound like a great tip.  I couldn't get to your link for some reason though.  I got
an error message when I tried to enter the folder.
Mark
pattern
about
me.
have
> Regards,
> Mike
> > Hi.
> still
> either
> structure
and
> I
compared
> to
> laptop
in
sequencing,
enough
> > processors.
> modern
> little
> > Thanks,
> > Mark
Re: [xl7] Re: Song construction tips?
2005-07-26 by Aaron Eppolito
That's how I'd work.  The XL-7 is a great way to capture ideas.  It's
fast, non-stop, and unencumbered.  It's not, however, a great way to
finish a song.  I think of mine as a 16 track tape deck that I can go
back and change the sounds on later.  Using eloader, you can get the
patterns to a computer to do arrangement and finishing.  Then, using
eloader again, dump the finished song back down to the box for use
live...
-Aaron
> the xl-7 and then bringing them into the computer for song construction.
Do You Yahoo!?
http://mail.yahoo.com
Ah, I hadn't thought of using e-loader... is that an easy process?  I seem to remember
abandoning it save for an OS update because it was Mac OS9 only.
Mark
> live...
> -Aaron
> Do You Yahoo!?
