ELoader and the MAC
ELoader and the MAC
2005-02-16 by M A C Daddy
Anyone running this with a PowerMAC/Powerbook?  Was there any problems?
Re: ELoader and the MAC
2005-02-16 by vibesart
me: Powermac - no problems at all. Important to get OMS configured
correctly first - and then launch Eloader. After that - no problems at
all, just normal OS9 workarounds when (if) you get stuck, and that
means rebooting and opening OMS first - IF you get stuck. If you do
that and you are still stuck - it probably measn that OMS is not
configured correctly.
2005-02-16 by mike
To use eloader you need to be able to start up in OS9.  Opening Classic while OSx is
running won't work.  You'll also need the OPCODE OMS app.  If I remember correctly, it's
on the emu cd along with the eloader app.
I've had to keep my old iMac around just for the emu/elaoder.  My new Powerbook won't
start up in OS9.
Hope this helps
Mike
Anyone know if this will work on Panther OS 10.3.7?
new Powerbook won't
> start up in OS9.
> Hope this helps
> Mike
problems?
2005-02-16 by mike
I couldn't get it to work.  E-loader only works in OS9.
> new Powerbook won't
> > start up in OS9.
> > Hope this helps
> > Mike
> problems?
Re: [xl7] Re: ELoader and the MAC
2005-02-16 by Rich Williams
If you read the post you're replying to you'll see the answer, which
I've highlighted below
>new Powerbook won't
>>  start up in OS9.
>>  Hope this helps
>>  Mike
>problems?
>Yahoo! Groups Links
Tha's cool I guess.  I will have to install it on WinXP.
thanks ya'll...
> >new Powerbook won't
> >>  start up in OS9.
> >>  Hope this helps
> >>  Mike
> >problems?
> >Yahoo! Groups Links
2005-02-16 by PLASTICEFX@aol.com
In a message dated 2/16/05 11:28:02 AM Eastern Standard Time,
studio_6512@... writes:
no.  it will not...
plastic
mac OS X Panther user......
I just had an idea...
Can I use a midi program to download the midi patterns via something
like ProTools?
> studio_6512@y... writes:
> no.  it will not...
> plastic
2005-02-16 by Aaron Eppolito
No.  The XL-7 uses closed-loop (handshaked) file transfer.
-Aaron
> like ProTools?
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
2005-02-16 by steve_the_composer
I doubt it, unless ProTools implements the MMA's smf sysex transfer
protocol.
I believe E-Loader uses sysex commands to transfer the patterns. The
e-mu converts the patterns into sysex packets based on the MMA's
specifications for such transfers. E-loader reassembles the sysex
packets into standard midi files so you can store them on disk (and
vice versa).
--Steve
something
> like ProTools?
> > no.  it will not...
> > plastic
2005-02-17 by djnorythm
*I just had an idea...
 like ProTools?
No, you cannot 'download' the pattern, but you can record the midi outs
of your emu device into protools.  Once you have the recorded the midi
file into protools, you can use that to trigger a blank pattern w/ the same
preset voicings on your sound module.
