patch editior/midi question
2005-02-13 by jk
two questions
1. is there a patch editor for the commandstations
2. how to i embed sysex data in my track, i have a mk-6 and when i
send the data it says sent, but if i change the preset on the mk-6
then play back the px-7 which is "suppose" to have the sysex, it
won't change the preset, is it possible to store the patch locations
of my mk-6 in the pattern on my px-7 or do i have to save a
multisetup on the mk-6 each time i use sounds from it in my tracks
this is one thing i couln't figure out, i've had my mk-6 for over
two years and i used it with a kawai q-80, but i could never figure
this out, so i jus saved a multi for each song i did,and recalled it
for the proper sequence
help?
Re: patch editior/midi question
2005-02-14 by steve_the_composer
--- In xl7@yahoogroups.com, "jk" <saintjoe@s...> wrote:
> two questions
I had the pleasure of betatesting a low-cost editor/path librarian
designed for  the p2k line (12-controller and 16 controller formats)
for Windows.  If you have a PC and want to test-drive out a demo
version to see how it works, check out
http://members.aol.com/caldor2004/patchpro/ . The demo will not save
banks of presets, but you will get a feel for the software.
There are other editors which some users have discussed here as well.
> locations of my mk-6 in the pattern on my px-7 or do i have to
> save a multisetup on the mk-6 each time i use sounds from it in my
> tracks
(1) It sounds like you want to store a prgram change [preset change]
command, not embedded sysex data.
(2) The command stations/P2500 do not have a sysex data editor, so
you cannot edit sysex data in your tracks.
(3) They do have an event editor which you can use to insert or edit
program schanges [preset changes]. Here's how:
-->Press Edit Pattern.
-->Scroll to the EVENT <-> menu.
-->Press Enter.
-->Select the track where you want to insert the program change
command.
-->Press Repeat to insert an event.
-->Rotate the type of event until you see prog:0
[You can also change the time and the channel.]
Bank switching works as follows:
msb [m;] selects your ROM [User = 0]
lsb [l:] selects the bank
EXAMPLE:
T02 EVENT <-> 003.01.000
C07 prog:85 m:66 l:1
At measure 3, beat 1, tick 0 on track 2 there is a program change
command to change the preset on midi channel 7 to 085^1 of the
Advanced Orchestra ROM (m:66).
Foot notes:
(1) You can recall multis using this command.  Simply use m:80. Be
sure to save your current setup first, otherwise it will be
overwritten.
(2) To send program changes to external gear, CHANNEL ASSIGN must be
set to >ext<. If you select >both<, the program change will not go
out to your external gear.
Hope this helps.
--Steve
> figure this out, so i jus saved a multi for each song i did,and
> recalled it for the proper sequence
> help?
Re: [xl7] Re: patch editior/midi question
2005-02-14 by Joseph Swopes
thanks, i had actually stumbled upon this, but one thing i can't figure out
how do you calculate the rom numbe, like, you said 66 for advanced orchestra, how do i calculate that
i'm jus trying to get my head around this, thanks
> two questions
> tracks
-->Press Enter.
command.
EXAMPLE:
Foot notes:
overwritten.
Hope this helps.
--Steve
> help?
Yahoo! Groups SponsorADVERTISEMENT
document.write('');
Yahoo! Groups Links
   To visit your group on the web, go to:
Press audition to find the ROM number. (There are lists of ROM ids,
but you really only need the ones installed in your e-mu.)
--Steve
> figure out how do you calculate the rom numbe, like, you said 66
thanks man!!
by the way, where is that list of id's
--Steve
document.write('');
Yahoo! Groups Links
