USB connector snapped off
2005-02-07 by Justin Grimley
Just a warning to everyone to be careful connecting/disconnecting
your USB cable.  I was removing (gently by the way) the cable tonight
when the connector snapped off the board and rattled inside the unit.
I tried super-gluing it back on (I know I'm an eejit) but it wouldn't
hold so I'm getting someone to solder it in the morning.
-grimley
Re: USB connector snapped off
2005-02-07 by malik
sorry about that man that sucks
> -grimley
2005-02-08 by gonzinigonz
Same happened to me. I thought mine had broken away from the PCB but
it had just un-clipped itself from the board.
I managed to pop in back in..
Your right in what you say though.. all those USB, Firewire etc
connections are very prone to damage.
I managed to repair a friends ipod yesterday. They had managed to
break off the firewire socket. Not only that, they found that if they
forced the plug in the socket and moved it around with force (enough
to make big black slodges on the LCD!!! animals..)that it might make
a connection and start charging.
The out come of all this was they had managed to break a track in the
middle layer of the PCB, so even though i soldered the socket back on
it still didnt work. 45mins later with a multimeter and magnifiing
glass i sussed out what was wrong. re-conected the ground to a
convenient point and it burst into life..
So yes whatch out for that one..
G
Sorry for the off topic, well it was sort of related..
tonight
unit.
wouldn't
> -grimley
2005-02-08 by Justin Grimley
Well, I had someone in work here solder it back on.  He took great
care and used a large magnifying gizmo to make sure none of the PCB
tracks were cracked ... but still no joy.  USB is toast, so now back
to slow-mo midi.
-grimley
but
they
(enough
make
on
> G
> tonight
> unit.
> wouldn't
> > -grimley
