Arps ans midi channel routing..
2005-01-08 by gonzinigonz
Hi All
Been playing around with the arps controlling my synths.
I having a few problems understanding how the midi channel routing
works out.
This is what i want to do:-
This is just using the trigger mode with the controllers set to latch
Track 9  = Kick on midi channel 9
Track 10 = HH   on midi channel 9
Ive used 2 differant presets / arp patterns on each track to get the
differant drum parts. It works fine if i had each part on a differant
midi channel but as soon as i make them both channel 9 it will only
play the last selected arp on that midi channel.
So can you not have 2 differant arps sharing the same midi channel?
How does the claim that you can run 32 arps at once work out?
Reghards
Gonz
Re: [xl7] Arps ans midi channel routing..
2005-01-08 by BEAUFILS Adrien
gonzinigonz <gonzini@...> wrote:
Hi All
works out.
Reghards
Gonz
If you program trigger 9 to play on channel 9 and trigger 10 to the same channel it won't work but perhaps i miss something about the multi/omni mode .
Yahoo! Groups Links
   To visit your group on the web, go to:
 Découvrez le nouveau Yahoo! Mail : 250 Mo d'espace de stockage pour vos mails !
Créez votre Yahoo! Mail
2005-01-08 by Greg Waltzer
An arp only operates on one midi channel.
You can have 32 arps because there are 32 midi channels (16 each on A
and B).
You couldn't have more than one arp on a single midi channel, because
each arp would try
to process all the notes on that channel.
gonzinigonz wrote:
>Hi All
>works out.
>Reghards
>Gonz
>Yahoo! Groups Links
Re: Arps ans midi channel routing..
Ok, i can sort of come to terms with that one..
l'll have a play around with the beats mode and see what comes out of
that.
Cheers
Gonz
A
> and B).
because
> each arp would try
> gonzinigonz wrote:
> >Hi All
> >works out.
latch
differant
only
> >Reghards
> >Gonz
> >Yahoo! Groups Links
