louder drums
louder drums
2004-10-31 by universumsmedelpunkt
Hello.
What do you all do to get those drumkits louder?
If one compares the xl7 chip with the "phatt" chip the drums are way
louder on the latter. As they should be.
I have 4 chips in my unit,the xl7,"phatt"whatever,composer,and world.
There is a big difference in volume between them.
My main annoyance is that its hard to get the xl7 drums to cut
through.This is supposed to be a dance chip and the drums got to be
at max.Right now Im trying to work with the alternative outputs and a
insert compressor and a gain stage.This works but it would be better
if I did not need the extra hardware.Any Ideas?
Re: [xl7] louder drums
2004-11-01 by Wesley D
you could double them up on separate layers.  some
filters make things a lot louder, like megasweepz.
personally though, I'd record each hit into a DAW at
the highest possible level withoug clipping and then
compress, EQ, etc.  that means you have to rely on a
sampler or a computer to trigger it back live.
but honestly, not even just the loudness, to me the
drums don't pack the same punch that a professional
recording does.  if you're at a gig and a DJ either
plays before or after you, my experience has been with
the XL rom that my beats didn't hit the same.  the
kick especially.  hip hop and techno get this kick
that sounds really deep and powerful.
if anybody has a secret to making super fat kicks
please share. (on or off the actual XX-7) I have two
tips.
first, gate a tone across it, route a send from the
kick to a low sine tone ( like 40 hz. or thereabouts)
then when the kick hits it opens up the tone.  40 is
the hip hop standard.
another sweet trick is to take an eq, and turn the
Q/bandwith as narrow as it will go, jack the gain all
the way up, then sweep the low freq. until you find
the sweet spot.  add as much as 10 dB to that freq.,
and they say 51hz. is a magig freq. for techno.
peace,
wesley
Do you Yahoo!?
Take Yahoo! Mail with you! Get it on your mobile phone.
http://mobile.yahoo.com/maildemo
Re: louder drums
2004-11-02 by universumsmedelpunkt
Thanx for your response.
Sampling hits is what I have been doing myself.Or better yet make
rythms,compress and maximize on the computer and then re sample the
loop...
However I must say that a compressor/limiter with a gainstage inserted
is working greater than expected.Im using a cheap Bheringer
composer.Then I can also play around with sending basslines and
percussion into the thing for extra fun.
If you then send the stereo input into a dynamic expander the output
will sound almoust like.....the way I like it.
keep it banging.
Re: louder drums
2004-11-02 by gutman75
The trance gurus from Israel, Infected Mushroom, have a "kick drum
tutorial" on their site:
http://www.infected-mushroom.net/Studio/Html/_Kickdrum_Tutorial.htm
Trance is not everybody's cup of tea, but their kicks have tons of
punch.
Apparently, they take a sine wave and then repeatedly apply a sharply
descending pitch envelope. I tried to do something similar on MP-7,
without much success. Maybe the envelopes are not fast enough?
2004-11-02 by erik_magrini@Baxter.com
I typically layer the drum sounds, and set AmpVol to +10 if I need it that
loud.  If you want a really beefy kick, layer the BD's, and use the
Megasweepz filter one of the layers.
Hello.
Yahoo! Groups Links
material from any computer.
For Translation:
but honestly, not even just the loudness, to me the drums don't pack the
same punch that a professional recording does.
>>>Well, to be fair, the XX-7's drums aren't compressed and EQ'd either.
So out of the box they are very natural sounding, which does lead to an
issue depending on if you use the box for studio or stage work.  In the
studio, I much more prefer it the way it is, that way I can use much
better compressors than would have ever been included on the XX-7 to punch
up the drums.  Live however, this is more a problem and you generally have
to resort to subbing the drums out to a seperate out or applying global
compression. <<<
if anybody has a secret to making super fat kicks please share. (on or off
the actual XX-7) I have two tips.
>>>Layer, Layer, Layer! <<<
add as much as 10 dB to that freq.,and they say 51hz. is a magig freq. for
techno.
>>>Way too low IMO, try a shelving EQ set at abvout 80-90Hz. <<<
Do you Yahoo!?
Yahoo! Groups Links
For Translation:
2004-11-03 by Wesley D
shelving is fine, but having a spike somewhere in the
subsonic range can really give a kick the low end
thump that many hip hop and techno producers are
looking for.
I too would suggest some type of shelf, or rolling off
of   the subsonic frequencies.  especially depening on
the track, if you have a really deep bass, you would
certainly want to open up some space down there.
in particular I'm speaking to progressive house/breaks
on that 51hz. tip.  more or less the advice that was
given to me by more than one very successful producer
was to take a narrow spiked eq and search for a freq.
that resonates well, or baically sounds fat.  it
doesn't always sound good.  I recently used waves
maxxbass on a kick to get some low end that just
wasn't in the kick to begin with.
I'm about to read the infected mushroom article.  I
must say though, I've never thought of them as having
really thick kicks.  I want kicks like Luke Chable's,
Infusion, PVD even (not so much recently).  those club
kicks that absolutely shake the building and you can
hear them from a block away.  it's hard to not have a
kick sound overdriven, blocky, or too high pitched, or
muffled and muddy when going for this type of thump.
it's a delicate blend of elements, and I personally
consider it the holy grail, being able to make a
plethura of different kicks that all kick ass.
wait, one tip I forgot to mention.  I sampled a kick
off of a record I have, a really really big one.  and
I noticed, after spectral analysis, that it appears to
go from high to low really fast.  like a wave.  so I'm
thinking it's a really subtle pitch bend really quick
over the sample.  sounded like infected mushroom was
talking about doing the opposite?  let me go read
that.  I've typed to much anyway.  sorry bout' that.
watching this election nonsense and the sopranos and
babbling.
peace,
wesley
Do you Yahoo!?
Check out the new Yahoo! Front Page.
www.yahoo.com
2004-11-03 by erik_magrini@Baxter.com
That's pretty much the standard way to synthesize a kick drum, very fast
downward pitch modulation.  Read the Synth Secrets article in Sound On
Sounds' online section for more info:
http://tinyurl.com/5hqqx
http://tinyurl.com/537bg
over the sample.
For Translation:
PX7 I have User, and Drum, and not very many sounds
2004-11-05 by Wesley D
Ok,
It appears as if I'm missing the factory sounds, which
I thought were imbedded.  in a quick search I found
two suggestions, one:  copy the factory sounds bank by
bank into the user slots.  two:  factory reset and
then use e-loader.
thing is, I'm not seeing any factory presets, so is
there a possiblilty that I'm missing the actual ROM or
something?
btw, how do you do a factory reset?  it wasn't under
facory reset or initialize in the manual.
thanks,
Wesley
Do you Yahoo!?
www.yahoo.com
Re: [xl7] PX7 I have User, and Drum, and not very many sounds
on closer inspection.... It seems either I'm crazy, or
the synth was acting weird, or I was in the wrong
menu....
it does seem weird that it says DRUM & User though...
-wesley
Do you Yahoo!?
www.yahoo.com
2004-11-05 by Bruddah Max
> something?
the presets are built into the ROMs - check if the ROM has worked
itself loose.
hold down both cursor keys at startup - scroll through the diagnostics
menu that comes up - reset is an option.
Bruddah Max
Lord of the Dance
2004-11-05 by BEAUFILS Adrien
Wesley D <Serfiss@...> wrote:
Ok,
then use e-loader.
something?
thanks,
Wesley
When you switch on your xl7 stay your legs lean against the 2 buttons cursors. After if you choose number 16 it will initialize all users data. If you choose number 17: idem except sequence data.
Tchao.
Do you Yahoo!?
www.yahoo.com
Yahoo! Groups Sponsor
Get unlimited calls to
U.S./Canada
Yahoo! Groups Links
   To visit your group on the web, go to:
Créez gratuitement votre Yahoo! Mail avec 100 Mo de stockage !
Créez votre Yahoo! Mail
Le nouveau Yahoo! Messenger est arrivé ! Découvrez toutes les nouveautés pour dialoguer instantanément avec vos amis.Téléchargez GRATUITEMENT ici !
Re: louder drums
2004-11-07 by robotchas
> rEalm
Another trick is to use one of the highpass filters, boost the resonance, and dial the
frequency until you find the fundamental of the bass drum. This can easily get really
loud...
I usually use two layers, one for the "attack" or "crack" to give the drum some character
(generally one of the more realistic sounds, lowpass filtered) and a second smoother
sound (sometimes even just a sine wave) for the body. The second layer gets the HPF
resonance bump and/or a rapid pitch ramp (high to low).
