command station life: how long do they last?
2004-09-17 by infradead
i was perusing my OS2.0 manual addendum when i came upon this line
beacuse flash RAM has a finite number of write operations before it
goes bad
which made me worry?
so this means eventually its gonna crap out on me?
is the flash RAM replaceable when the time comes?
Re: command station life: how long do they last?
2004-09-17 by gonzinigonz
> goes bad
Wouldnt worry about it, well over 100,000 write cycles i would
imagine.
Sure the ram could be changed if it came to it anyway.
Gonz
> imagine.
> Gonz
stupid question time
what's a write cycle?  is that everytime the flash compacts or
everytime you save..
thanks
> > imagine.
> > Gonz
> thanks
Sorry, yes in other words every time you save or compact the user ram.
(compacting will use many write cycles, "not for everyday use" like
it tells you..)
Flash rams life is measured in write cycles, ie how many times you
should be able to change the data stored in it reliably.
G
Re: [xl7] Re: command station life: how long do they last?
2004-09-17 by Aaron Eppolito
> ram. (compacting will use many write cycles, "not for everyday use"
like
> it tells you..)
Regular writes don't really count because they're not erasing anything.
 Compaction will use two write cycles per flash block.  Essentially
nothing you'll have to worry about.  I posted a very long discussion
about this a long while back.  If the archives didn't suck so much, I'd
suggest searching for it, but it would take you forever to find.
-Aaron
_______________________________
Do you Yahoo!?
Declare Yourself - Register online to vote today!
http://vote.yahoo.com
use"
> like
> > it tells you..)
anything.
I'd
> -Aaron
> Do you Yahoo!?
Cheers Aaron, i should of said 'erase' cycles to be correct :o)
G
